Hello, I have been trying MAX30100 heartbeats and oxigen saturation sensor with Arduino Mega for a while, and there is no way I can make it work. It doesn't even turn the leds on, it has integrated a red and a infrarred led, but they don't turn on. When I plug it to my Arduino it doens't give me any message or signal of work in the serial port. I have been using it with the default Arduino library I downloaded from GitHub - oxullo/Arduino-MAX30100: Arduino library for MAX30100, integrated oximeter and heart rate sensor but it doensn't do anything. What can be the problem? I have plugged VIN to Arduino 5V (or 3.3V, doesn't do anything with both) GND to Arduino GND, INT to pin 2 and SCL and SDA to A4 and A5 pins in the Arduino. I can see people use resistors on SDA and SCL pins buth I don't know why should I. Do you know what the problem is? Am I plugging it the wrong way? Is it the sensor? Or the Arduino? If you can show me a working example it would be great.
Try the Sparkfun example code.There is a heart rate & spO2 example.
Because the resistors are absolutely required.
jremington:
True, but many breakout boards have them installed, and the Mega OP is using already has 10k pull up resistors to 5volt (which might not be ok for a 3.3volt sensor).
A Mega uses pin 20 and 21 for I2C, not A4, A5.
There are many variations of that MAX breakout board.
Post a link to the one you're using, and YOUR wiring diagram.
Read the "how to post" sticky first.
Leo..
