Max7219 iwht 8x8 matrix, how?
So I just started a project in which I controll an 8x8 led matrix with an IR sensor, and after some research I found out that my LED matrix should be on a chip where it connects to a max7219 directly transforming it in an (i believe) i2c device. I have a max7219 chip but I do not have the chip where I place the matrix and the driver. I've seen a montage without the max 7219 which takes waaaaay to many pins (12 digital pins and 4 analog) leaving me with no space for the IR sensor. Besides, the matrix just displays nonsense. I will leave below the image.
#include <FrequencyTimer2.h>
#define SPACE { \
    {0, 0, 0, 0, 0, 0, 0, 0},  \
    {0, 0, 0, 0, 0, 0, 0, 0} \
#define H { \
    {0, 1, 0, 0, 0, 0, 1, 0}, \
    {0, 1, 1, 1, 1, 1, 1, 0}, \
    {0, 1, 0, 0, 0, 0, 1, 0}  \
#define E  { \
    {0, 1, 0, 0, 0, 0, 0, 0}, \
    {0, 1, 1, 1, 1, 1, 1, 0}  \
#define L { \
#define O { \
    {0, 0, 0, 1, 1, 0, 0, 0}, \
    {0, 0, 1, 0, 0, 1, 0, 0}, \
    {0, 0, 0, 1, 1, 0, 0, 0}  \
byte col = 0;
byte leds[8][8];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
// col[xx] of leds = pin yy on led matrix
int cols[8] = {pins[13], pins[3], pins[4], pins[10], pins[06], pins[11], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix
int rows[8] = {pins[9], pins[14], pins[8], pins[12], pins[1], pins[7], pins[2], pins[5]};
const int numPatterns = 6;
byte patterns[numPatterns][8][8] = {
  H,E,L,L,O,SPACE
int pattern = 0;
  // sets the pins as output
  for (int i = 1; i <= 16; i++) {
    pinMode(pins[i], OUTPUT);
  // set up cols and rows
  for (int i = 1; i <= 8; i++) {
    digitalWrite(cols[i - 1], LOW);
    digitalWrite(rows[i - 1], LOW);
  clearLeds();
  // Turn off toggling of pin 11
  FrequencyTimer2::disable();
  // Set refresh rate (interrupt timeout period)
  FrequencyTimer2::setPeriod(2000);
  // Set interrupt routine to be called
  FrequencyTimer2::setOnOverflow(display);
  setPattern(pattern);
    pattern = ++pattern % numPatterns;
    slidePattern(pattern, 60);
void clearLeds() {
  // Clear display array
  for (int i = 0; i < 8; i++) {
    for (int j = 0; j < 8; j++) {
      leds[i][j] = 0;
void setPattern(int pattern) {
      leds[i][j] = patterns[pattern][i][j];
void slidePattern(int pattern, int del) {
  for (int l = 0; l < 8; l++) {
    for (int i = 0; i < 7; i++) {
        leds[j][i] = leds[j][i+1];
      leds[j][7] = patterns[pattern][j][0 + l];
    delay(del);
// Interrupt routine
void display() {
  digitalWrite(cols[col], LOW);  // Turn whole previous column off
  col++;
  if (col == 8) {
    col = 0;
  for (int row = 0; row < 8; row++) {
    if (leds[col][7 - row] == 1) {
      digitalWrite(rows[row], LOW);  // Turn on this led
    else {
      digitalWrite(rows[row], HIGH); // Turn off this led
  digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
That's the code. So my question is: How can I connect the max 7219 to my 8x8 LED matrix?
Thanks in
advance
