MAX7219 with Arduino
Im having trouble trying to figure out how to set up the MAX7219 chip, in the startup routine.... I see there is supposed to be an ledcontrol.h file that is supposed to help. My arduino compliler says there is no such library though....
Any suggestions on how i can get this thing programed and through the start up section?
Thanks!
Zack
Here's what I did. I don't use libraries a lot, preferring to read the data sheet & understand what's going on. Doesn't make for the greatest code sometimes, and there's plenty of room for improvement.
You'll have to do some variable declarations too.
// addresses for the MAX7221, and the values/ranges to write in
#define DECODE_MODE 0x09 // write data 0xFF, Code B Decode for all digits
#define INTENSITY_ADDRESS 0x0A // 0x07 to start, half intensity. valid from 0x00 (min) to 0x0F (max)
#define SCANLIMIT_ADDRESS 0x0B // 0xFF, all 8 digits on
#define SHUTDOWN_ADDRESS 0x0C  // 0x01, normal operation (0x01 = shutdown) - powers up in shutdown mode
#define DISPLAYTEST_ADDRESS 0x0F // 0x01 = all lights on full, 0x00 = normal ops
#define leftscore_tens_address 0x01 // digit 0, leftscore_tens+left_yellow, fill right hand byte with data to display
// data = 0-9, A='-', B='E', C='H', D='L', E='P', F=blank
#define leftscore_ones_address 0x02 // digit 1, leftscore_ones+right_yellow
#define rightscore_tens_address 0x03 // digit 2, rightscore_tens+right_red
#define rightscore_ones_address 0x04 // digit 3, rightscore_ones+right_yellow
#define minutes_tens_address 0x05 // digit 4, minutes_tens+colon
#define minutes_ones_address 0x06 // digit 5, minutes_ones+left_priority
#define seconds_tens_address 0x07 // digit 6, seconds_tens+right_priority
#define seconds_ones_address 0x08 // digit 7, seconds_ones+swap
void setup() // stuff that runs once before looping forever
  // start up SPI to talk to the MAX7221
  SPI.begin(); // nothing in () because we are the master
  pinMode(SS, OUTPUT);  // Slave Select for SPI  <--- Need this here before any SPI writes
  //  MAX7221: write shutdown register
  digitalWrite(SS,LOW);  // take the SS pin low to select the chip:
  SPI.transfer(SHUTDOWN_ADDRESS);  // select the Address,
  SPI.transfer(0x00);      // select the data, 0x00 = Outputs turned off
  digitalWrite(SS,HIGH);   // take the SS pin high to de-select the chip:
  // Serial.println("shutdown register, dislays off");
  // put known values into MAX7221 so doesn't have weird display when actually turned on
  // 0x0F = blank digit
  SPI.transfer(leftscore_tens_address);  // select the Address,   <<< these are the addresses of the 8 data registers
  SPI.transfer(0x0F);      // select the data
  SPI.transfer(leftscore_ones_address);  // select the Address,
  SPI.transfer(rightscore_tens_address);  // select the Address,
  SPI.transfer(rightscore_ones_address);  // select the Address,
  SPI.transfer(minutes_tens_address);  // select the Address,
  SPI.transfer(minutes_ones_address);  // select the Address,
  SPI.transfer(seconds_tens_address);  // select the Address,
  SPI.transfer(seconds_ones_address);  // select the Address,
  //  MAX7221:
  //  write intensity register
  SPI.transfer(INTENSITY_ADDRESS);  // select the Address,
  SPI.transfer(intensity);      // select the data
  //Serial.println("intensity register ");
  // write scanlimit register
  SPI.transfer(SCANLIMIT_ADDRESS);  // select the Address,
  SPI.transfer(0xFF);      // select the data - FF = all 8 digits
  //Serial.println("scanlimit register ");
  // write decode register
  SPI.transfer(DECODE_MODE);  // select the Address,
  //Serial.println("decode register ");
  //display test
  SPI.transfer(DISPLAYTEST_ADDRESS);  // select the Address,
  SPI.transfer(0x01);      // select the data
  //Serial.println("digit display test on ");
  delay (100);
  //Serial.println("digit display test off ");
  delay (100);
  // write shutdown register for normal display operations
  SPI.transfer(0x01);      // select the data, 0x01 = Normal Ops
  //Serial.println("shutdown register, displays on ");
Thank you so much! you even have comments!
Ill go through it here in a bit, ill see if i can get this thing working!
I appreciate it!
Zack
btw, what is SPI.transfer? i havent seen this yet, im still kinda new to all of this.
I also see a pin called SS, what pin is this? example "digitalWrite(SS, HIGH);
The approach of CrossRoads is very good and I myself like to read the datasheet and understand the protocol, but sometimes I'm interested more in programing fast and clean. This is the main reason I recently started working with arduino. If you don't have the ledcontrol library you should download it an compile an empty sketch with it. Here, I've looked it up for you and you'll find some examples in there as well:
http://arduino.cc/playground/Main/LedControl#Source
Here my method. I use shiftOut(); to send the data into the MAX7219.
And I recomend you download the datasheet here : http://www.datasheetcatalog.org/datasheet/maxim/MAX7219-MAX7221.pdf and read it multiple times to make sure you understand. Don't forget about R set. It limit the current going into a segment. I set my circuit about 56 K to 68 K. I want to limit the segments current between 5 mA to 15 mA to be safe. If you want a bigger currents, well use a transistor to control the segments.
Here my test code. My code is simply this : Display 1,2,3,4,5,6,7,8 for a second and display 8,7,6,5,4,3,2,1. I use Mode 3. For a multiples leds paterns, use No Mode. To further understand this... read the datasheet. The MAX7219 init is in the setup. I don't use SPI. I use shiftOut(). I have the flexibility of choosing the output pins. And beside, I have 70 chips at my place. I better learn to use it. I do have a code for a multiples leds. I use No Mode. The other test code simply count 0 to 255 in binary. Use Leds arrays has leds.
If you want to design program for the MAX7219, think in HEX and in BINARY. Use Arrays a lots. And a lots of for() loops.
Mode 3 test code.
const byte datapin = 12;
const byte latchpin = 11;
const byte clockpin = 10;
 pinMode(datapin, OUTPUT);
 pinMode(latchpin, OUTPUT);
 pinMode(clockpin, OUTPUT);
 // set : Normal Mode
 digitalWrite(latchpin, LOW);
 shiftOut(datapin, clockpin, MSBFIRST, 0x0C );
 shiftOut(datapin, clockpin, MSBFIRST, 0x01 );
 digitalWrite(latchpin, HIGH);
 delay(5);
 // set : Normal Operation
 shiftOut(datapin, clockpin, MSBFIRST, 0x0F );
 shiftOut(datapin, clockpin, MSBFIRST, 0x00 );
 delay(5);
 // set : Intensity
 shiftOut(datapin, clockpin, MSBFIRST, 0x0A );
 shiftOut(datapin, clockpin, MSBFIRST, 0x0B );
 delay(5);
 // set : Numbers of digits
 shiftOut(datapin, clockpin, MSBFIRST, 0x07 );
 delay(5);
 // set : Decode Mode Register
 shiftOut(datapin, clockpin, MSBFIRST, 0x09 );
 shiftOut(datapin, clockpin, MSBFIRST, 0xFF );
 byte j;
 for (int i=1;i<9;i++)
   shiftOut(datapin, clockpin, MSBFIRST, i );
   delay(5);
 delay(2000);
 j = 8;
   shiftOut(datapin, clockpin, MSBFIRST, j );
   delay(5);
   j--;
 delay(2000);
Here the No Mode test code.
byte display_number[8] = {0,0,0,0,0,0,0,0};
 pinMode(13, OUTPUT);
 digitalWrite(13, LOW);
 delay(5);
 delay(5);
 // set : Intensity
 delay(5);
 delay(5);
 delay(5);
 // set display to zero
 display_the_max();
 for (int j=0;j<8;j++)
   for (int i=0;i<256;i++)
     display_number[j]=lowByte(i);
     display_the_max();
     delay(25);
   display_number[j]=0;
   display_the_max();
   digitalWrite(13, HIGH);
   delay(5000);
 delay(2000);
void display_the_max()
 for (int k=0; k<8;k++)
    shiftOut(datapin, clockpin, MSBFIRST, (k+1));
    shiftOut(datapin, clockpin, MSBFIRST, display_number[k]);
    delay(5);
SS is slave select. To control the 7219 via its SPI interface, you take slave select low, use the internal hardware to send the data out real quick (write 2 bytes, vs all the software needed for the shiftout() command), and then take slave select high to let the 7219 know you're done talking to it.
The ATmega has built in hardware for the Serial Peripheral Interface - your code writes a byte to a register, the hardware uses buit in shift registers to crank the data out. Versus the software method which does something like this:
set the output pin to match bit 0 of the byte being sent (if using LSBFIRST, and pin7 if using MSBFIRST)
set the clock pin high
set the clock pin low
set the output pin to match bit 1 of the byte being sent (or bit 6, see above)
(and repeat 6 more times)
so a lot more steps involved.
ledcontrol.h does all the same stuff, it just hides that it is doing it in a "library", and also uses the software shift method as it lets you define the pins to be used. SPI uses pins 13-12-11, and you can define something besides pin 10 if you want as the SS pin.
Does the 7219 support SPI? I thought only the 7221 version did? (I could be wrong though?)
I too found the ledControl library a nice and easy lib to use.. especially for beginners.. but if it does support SPI.. its a good thing to learn about.
imzack:
Techone, MSBfirst, is that a variable that arduino knows? or is that something else?
Also still having trouble with getting the LedControl.h library, it says it's not there. I tried to update it, says its 1.0, im on ubuntu btw.
Alarm_Clock.cpp:31:88: error: LedControl.h: No such file or directory
Alarm_Clock:44: error: ‘LedControl’ does not name a type
Alarm_Clock.cpp: In function ‘void setup()’:
Alarm_Clock:146: error: ‘lc’ was not declared in this scope
Alarm_Clock.cpp: In function ‘void loop()’:
Alarm_Clock:247: error: ‘lc’ was not declared in this scope
Alarm_Clock:255: error: ‘lc’ was not declared in this scope
Alarm_Clock:263: error: ‘lc’ was not declared in this scope
Alarm_Clock:271: error: ‘lc’ was not declared in this scope
#include <LiquidCrystal.h>  //Used for the LCD Module   HAVE TO GO TO SKETCH-> Import Library...
#include "LedControl.h"  // This library helps with using the 7-segment driver(MAX72XX)
pin 12 is DataIn
pin 11 is CLK
pin 10 is LOAD (Latch)
const int Data = 12;        // Data line into the chip
const int CLK =  11;       //CLOCK Signal for the chip
const int LOAD = 10;       //The pin to control the latch or load value on chip
const int driver_num = 1;  //number of MAX72XX's we are linked or using in total
LedControl lc=LedControl(Data,CLK,LOAD,driver_num);  //this line assigns the pins to what we have labeled in the comment block above (is it lc or lcl in this line?)
                                                    //The last number states how many devices aka how many MAX72XX's  Note: the lc is just a variable that is created
        int countOnes = 0;  // will keep track of seconds
        int countTwos = 0;  // will keep track of tens of seconds
        int countThrees = 0;  // will keep track of minutes
        int countFours = 0;  // will keep track of tens of minutes
        int countFives = 0;  // will keep track of hours
        int countSix = 0;  // will keep track of tens of hours
        int amPM = 0;      // low for AM, High for pm
//INTERRUPT SERVICE ROUTINE FOR TIMER 1
    ISR(TIMER1_OVF_vect) {
              TCNT1 = 0xC180;      //this resets the timer to this preloaded value after every overflow
              milliseconds = milliseconds + 1;    //increments this 1 each time an overflow occurs
void setup() {                   //Code to be run 1 time goes here
//*******************************************TIMER INITIALIZATION CODE************************************************************
TIMSK1 = 0x01;
TCCR1A = 0x00;
TCNT1 = 0xC180;        //Reload value of 49,536, so we can get a 1millisecond clock...
TCCR1B = 0x01;        //No prescaler  (page 137 Atmel Datasheet)
//wakes up the MAX72XX from power-saving mode
lc.shutdown(0,false);
//set a medium brightness for the display
lc.setIntensity(0,8);  //this sets intesity for digits 0 to 3
//clear display
lc.clearDisplay(0);
// initialize the digital pin as an output.
// Pin 13 has an LED connected on most Arduino boards:
This is my header files that i include btw and the setup that im doing.... direct copy and paste...
Moderator edit: [code] ... [/code] tags added. (Nick Gammon)
Did you add the LedControl library to your library directory?
No, i was under the assumption that the newest version had it included... let me see about doing that, im in ubuntu and still trying to get used to this aswell.
Ok, i went to the site on the arduino section on the LEDControl section, downloaded the zip, extracted it, then put it in the library folder.
I now ran my code, and with everything wired up the only segments thus far that are lit up is the decimal point, ill see whats wrong with my code now, but im happy to see progress!
Thanks,
Zack
#include <SPI.h>
pin 12 is DataIn
pin 11 is CLK
//Constants wont change
Gets the max number of devices attached to the LedControl
Returns the number of devices attached
          //int LedControl::getDeviceCount();
// Variables that will change:  AKA software variables
        int milliseconds = 0;  //will keep track of milliseconds
TIMSK1 = 0x01;
TCCR1A = 0x00;
//clear display
lc.clearDisplay(0);
void loop() {                    //Infinate Loop
//BEGINING OF MAIN TIMER SECTION
      if(milliseconds == 1000){
                            milliseconds = 0;
                            countOnes += 1;  //after 1000 milliseconds, seconds will be incrmented 1
      if(countOnes == 10){
                            countOnes = 0;
                            countTwos +=1;
      if(countTwos == 6){
                            countTwos =0;
                            countThrees += 1;  //means that when 60 seconds pass, minutes is incremented 1
      if(countThrees == 10){
                            countThrees = 0;      // if 10 minutes goes buy, this goes to zero and the ten minutes spot gets incrmented one
                            countFours += 1;     // tens of minutes
      if(countFours == 6){
                            countFours = 0;    // Sixty seconds equal 1 hour
                            countFives += 1;  // hours is incremented
      if(countFives == 10){
                            countFives = 0;    //count to 9 hours, then when get to 10 hours the place gets rolled over
                            countSix += 1;
      if(countSix == 2){
                            countSix = 0;    //This can only get to the vaule of 0 or 1 any higher, it resets
                  if(amPM == 1){
                                  amPM = 0;    // this code inverts PM to am or vis versa
                  else{
                                  amPM = 1;
                        }    // end of countSix
lc.setDigit(0,0,countThrees, false);//seconds place output
        // device 0(only 1 Max72xx) , digit(0), number to output and then false
delay(1);
lc.setDigit(0,1,countFours, false);  // device 0(only 1 Max72xx) , digit, number to output and then false
delay(1);
 lc.setDigit(0,2,countFives, false); //hours place output
        // device 0(only 1 Max72xx) , digit(2), number to output and then false
delay(1);
lc.setDigit(0,3,countSix, false); //tens of hours place output
                                                              // device 0(only 1 Max72xx) , digit(3), number to output and then false
delay(1);
}          //END OF LOOP
//END OF MAIN TIMER SECTION
above is my code, attached are some pics of what i am getting, for some reason my dots are lit up, but the other stuff isnt lit up correctly, as you can see they all look the same and dont display numbers
also i have questions in the code that relates to that LEDCONTROL.h library
" lc.setDigit(0,0,countThrees, false);//seconds place output "
the line above for example, what does the false mean? and
does the 1st digit mean im talking to only 1 max72xx and the 2nd digit, means what acctual digit im programing correct?
Thanks,
Zack
hi-
while I havent messed with the ledControl lib for a while now.. (or been in the MAX72XX datasheet)
I think I remember something about blanking/initializing the chips before starting.. (should be outlined in the tut/library)
yes the first parameter means the chip you want to target I believe..you can have up to 8 daisy chained I believe..
the second is the 'led' you are targeting.. 3rd parameter is the state of the on or off..
you are using the 7xsegment led functions though.. which looks as if it takes an additional parameter...
You'd have to refer back to the documentation as I dont recall the 7-segment functions as I havent used them.
@imzack
In your code, this :
#include <SPI.h>
Can not be use at the same time. A confic here. I did look at LedControl.cpp file. The library use shiftOut() to send data to the max7219. So it conflic the SPI library. Pin 13 is the data and I think pin 12 is the clock. Just keep LedControl.h Delete the SPI.h
Yes, the Ardiuno IDE know what is MSBFIRST or LSBFIRST. It is use for shiftOut( datapin, clockpin, MSBFIRST, value_to_send_in_byte ); MSBFIST mean the last bit of the data to be send get out of the Arduino datapin first.
Example : 1011 - > number 11. So the Ardiuno send the bits in that order : Last bit out --> 1 -- > 1 --- > 0 --> 1 <-- First bit out
Thank you, I took out the SPI library at the top.
However, it didnt do anything different.
Below is the code that im using right now...
pin 12 is DataIn
pin 11 is CLK
TIMSK1 = 0x01;
TCCR1A = 0x00;
lc.shutdown(0,false);  //turns off shutdown mode, so you can display stuff
lc.setIntensity(0,14);  //this sets intesity for digits 0 to 3
//clear display
lc.clearDisplay(0);
                            milliseconds = 0;
                            countOnes = 0;
                            countTwos +=1;
      if(countTwos == 6){
                            countTwos =0;
                            countSix += 1;
      if(countSix == 2){
                  if(amPM == 1){
                  else{
                                  amPM = 1;
//lc.setDigit(0,0,0x04, false);//seconds place output  countThrees
delay(2000);
delay(2000);
delay(2000);
delay(2000);
lc.setChar(0,0,'0',false);
delay(2000);
lc.shutdown(0,true);  //turns off shutdown mode, so you can display stuff
delay(2000);
delay(2000);
lc.setChar(0,0,'1',false);
delay(2000);
lc.setChar(0,0,'2',false);
delay(2000);
lc.setChar(0,0,'3',false);
delay(2000);
lc.setChar(0,0,'4',false);
delay(2000);
lc.setChar(0,0,'5',false);
delay(2000);
lc.setChar(0,0,'6',false);
delay(2000);
lc.setChar(0,0,'7',false);
delay(2000);
lc.setChar(0,0,'8',false);
delay(2000);
lc.setChar(0,0,'9',false);
delay(2000);
lc.setChar(0,0,'a',false);
delay(2000);
lc.setChar(0,0,'b',false);
delay(2000);
lc.setChar(0,0,'c',false);
delay(2000);
lc.setChar(0,0,'d',false);
delay(2000);
lc.setChar(0,0,'e',false);
delay(2000);
lc.setChar(0,0,'f',false);
delay(2000);
}          //END OF LOOP
As seen at the bottom of my code i attempt to go through all the characters... but what i can see is no numbers, but the decimal points stay lit at all times, untill it enters shutdown mode, that works. then upon shutdown mode being turned off, the decimal points are lit again for and still nothing on the other segments...
Any ideas?
Also i will draw up a hardware diagram to see if that might be wrong too... i think its correct however, since ive gone through it multiple times.
Thanks agian!
Zack
Here is a diagram of what i have hooked up...
I also have a iset of 9.5k
other than that idk if i have it set up correctly or not... since it is acting odd
if someone could take a look it would be greatly appricated!
thanks,
Zack
