Okay, I've been working on this for a while and I want some feedback. This is a board for the Sparkfun RGB backpack with three MAX7221CWGs. I made it in DipTrace and it's double-layered if the silkscreen is left out when it's printed, it should work for toner transfers.
That link is for the schematic and I meant the matrix itself. Oh, and I am unsure about the size of the caps, but I placed them where they are to make them easy to change jic.
With the number of vias in the layout, etching this at home would be, if not impossible, very involved with lots of precision drilling and lots of tiny wire links to fill the vias.
All I get is the PCB layout from the links above and not the schematics.
Do I assume thought from the use of the drivers that this design will only produce 7 colours. That is you will not be able to mix various proportions of colours?
