MCUFRIEND TFT and I2C wont work together
I am having issues with setting up my TFT and my accelerometer that runs off of I2C. I am using a UNO R3 from Arduino(not a clone).
I have a random 3.2" TFT I found online that works well with MCUFRIEND when it is the only thing running but once I try and read from the accel, it shows the screen once then goes white/blank.
I found online that it is the A4 pin being used by the TFT thats causing the issue. I read that you can do a software reset instead but the thread applied to a specific controller and I am not sure that I have that controller. I am not sure if this is possible to do with mine and want to verify if so before I go hacking up my pins.
I have run the LCD_ID_readreg.ino and got this response but I have no clue how to read it and I cant find the rosetta stone for it either. I can load a picture of the Pinouts on the board if you need that as well.
Read Registers on MCUFRIEND UNO shield
controllers either read as single 16-bit
e.g. the ID is at readReg(0)
or as a sequence of 8-bit values
in special locations (first is dummy)
reg(0x0000) 00 00	ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 54 80 66	Manufacturer ID
reg(0x0009) 00 00 61 00 00	Status Register
reg(0x000A) 00 08	Get Power Mode
reg(0x000C) 00 66	Get Pixel Format
reg(0x0061) 00 00	RDID1 HX8347-G
reg(0x0062) 00 00	RDID2 HX8347-G
reg(0x0063) 00 00	RDID3 HX8347-G
reg(0x0064) 00 00	RDID1 HX8347-A
reg(0x0065) 00 00	RDID2 HX8347-A
reg(0x0066) 00 00	RDID3 HX8347-A
reg(0x0067) 00 00	RDID Himax HX8347-A
reg(0x0070) 00 00	Panel Himax HX8347-A
reg(0x00A1) 00 93 30 93 30	RD_DDB SSD1963
reg(0x00B0) 00 00	RGB Interface Signal Control
reg(0x00B4) 00 00	Inversion Control
reg(0x00B6) 00 02 02 3B 3B	Display Control
reg(0x00B7) 00 06	Entry Mode Set
reg(0x00BF) 00 00 00 00 00 00	ILI9481, HX8357-B
reg(0x00C0) 00 0E 0E 0E 0E 0E 0E 0E 0E	Panel Control
reg(0x00C8) 00 00 00 00 00 00 00 00 00 00 00 00 00	GAMMA
reg(0x00CC) 00 04	Panel Control
reg(0x00D0) 00 00 00	Power Control
reg(0x00D2) 00 00 00 00 00	NVM Read
reg(0x00D3) 00 00 94 86	ILI9341, ILI9488
reg(0x00D4) 00 00 00 00	Novatek ID
reg(0x00DA) 00 54	RDID1
reg(0x00DB) 00 80	RDID2
reg(0x00DC) 00 66	RDID3
reg(0x00E0) 00 0F 21 1C 0B 0E 08 49 98 38 09 11 03 14 10 00	GAMMA-P
reg(0x00E1) 00 0F 2F 2B 0C 0E 06 47 76 37 07 11 04 23 1E 00	GAMMA-N
reg(0x00EF) 00 80 00 10 60 40	ILI9327
reg(0x00F2) 00 18 A3 12 02 B2 12 FF 10 00 00 00	Adjust Control 2
reg(0x00F6) 00 54 80 66	Interface Control
I have also attached the code I was using to debug what the issue was by trimming everything away until I could change one line and I could replicate the issue and go back to working easily.
#include <Adafruit_GFX.h>    // Core graphics library
#include <MCUFRIEND_kbv.h>   // Hardware-specific library
MCUFRIEND_kbv tft;
#include <FreeDefaultFonts.h>
#define BLACK   0x0000
#define RED     0xF800
#define GREEN   0x07E0
#define WHITE   0xFFFF
#define GREY    0x8410
#include <Wire.h>
#include <SPI.h>
#include <SparkFunLSM9DS1.h>
// LSM9DS1 Library Init //
// Use the LSM9DS1 class to create an object. [imu] can be
// named anything, we'll refer to that throught the sketch.
LSM9DS1 imu;
// Example I2C Setup //
// SDO_XM and SDO_G are both pulled high, so our addresses are:
#define LSM9DS1_M  0x1E // Would be 0x1C if SDO_M is LOW
#define LSM9DS1_AG  0x6B // Would be 0x6A if SDO_AG is LOW
  Serial.println("GPS Read Example");
uint16_t ID = tft.readID();
    tft.begin(ID);
    tft.setRotation(0);
    Serial.println(ID);
  //imu.readAccel(); //code works until I uncomment this line.
  tft.fillScreen(BLACK);
  showmsgXY(20, 10, 1, NULL, "System x1");
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)
    int16_t x1, y1;
    uint16_t wid, ht;
    tft.drawFastHLine(0, y, tft.width(), WHITE);
    tft.setFont(f);
    tft.setCursor(x, y);
    tft.setTextColor(GREEN);
    tft.setTextSize(sz);
    tft.print(msg);
This is my first time posting so let me know if i missed any critical things. This is what I have seen asked in other threads so I figured I would throw it up here.
If I am right about it being the A4 pin, please tell me how to fix it in detail. I am not good at this stuff and trying to learn so somethings might go over my head if left vague.
Thanks for your help!
A4 is the LCD_RST pin. So if you operate anything on the Uno's I2C bus it will hardware reset the TFT.
I have published how to make a hardware mod.
Snip off the LCD_RST pin. Solder a 10k resistor from the stub that is left. Solder the other end to the 5V pin.
You have an ILI9486 controller. The tft.begin() call issues a software reset.
Call Wire.begin() after tft.begin() because tft.begin still wiggles the LCD_RST line.
I have no connection with mcufriend.com
You can access the SDA and SCL pins on a Uno R3 by using some angle header strip.
The simple answer is: A parallel TFT uses a lot of GPIO pins. The Uno does not have many GPIO pins.
David.
Having a very similar problem.
@David, could you share a link to your hardware mod? Is there more to it than what you mentioned here or should i just go ahead and set that pin to 1 :).
@njc711 what did you end up going for? I'm not sure i want to start cutting pins off my Arduino just yet. I'm hoping there's a software hack to somehow ignore the reset interrupt. Would be the cleanest way i think.
Thanks,
-Paul
You can Google for "MCUFRIEND_kbv i2c"
I found this message
You do not alter the Uno. The mod only affects the shield. And it only works for modern controllers.
What controller do you have?
It is simple to snip the LCD_RST pin. And then solder a 10k resistor from the top of the snipped pin to the 5V pin
David.
