Hi all,Suppose a machine is manufacturing a steel wire and that wire is being winded up on a spool/reel.In that process just before the wire winding on the spool,is there any way to calculate the length of the wire being produced.Actually I want to measure the weight of the wire that has already wounded up on the spool.So I was thinking of measuring the weight of a fixed wire length and then extrapolating the reading(total length produced) from the sensor data to get the approximate weight of the wire that is wounded up on the spool.
p.s can't dismantle the spool in between to measure the weight hence the requirement.
If coated: Measure wire resistance and compare to a wire resistance chart.
If not coated: subtract spool ID from spool OD and use "toroid volume" formula.
Electric cable rollers use a pair of rollers with a clamping arrangement and counter to measure the length of cable coming off a roll.
Imagine the same would aply in the reverse direction.
Run the wire through a metering device.
You can use a load cell and weight the spool when starting and again when finished.
Oddly enough, it's called a "wire meter". We used one to measure length for custom cables. I still have it in the shop and it's looking for a home! The machine making the wire uses either rollers for the wire or dies to reduce the wire diameter.
In either case there is most likely already a measuring device on the machine.
Maybe.
I'm amazed at how many machines don't come with obvious instruments like this built in already.
In my "project building freelance gig" I've been asked to build a slew of add-ons for various machines. In many cases, the add-ons are only sold with more expensive versions of the same machine. So someone might pay, e.g., $10,000 for an automated packaging machine, but the "packaged item counter" (which you'd think was an obvious thing to have) is only available on the $15,000 version of the same machine.
One of the weirdest (and simplest) things I was ever asked to build was to latch an alarm on a 6-figure laser cutter because the built-in end-of-operation alarm was only a few seconds long and easy to miss, so you'd have a very expensive machine sitting idle because no one realized that it was finished.
Hi, @1neox
How fast will the wire be travelling.
You are describing a wire extruding machine and by the time the wire is down to "wire" size it can be travelling at quite a few m/s.
Tom...
Yes something like that should work.
Like I said the spool can't be removed so can't weight it m afraid.
Yes,the wire being manufactured is called licker in wire used in textile industries.It is a sawtooth like wire.The final process includes the quenching where the wire is passed through and induction machine and an LPG burner into the quenching oil before being winded on a spool.Problem is that the spool could't be unloaded repeatedly to weigh the wire that has been wound.
I was thinking of something like a surveyor's wheel to measure the length of the wire.Would something like that work using rotary encoder etc?And yes it is travelling at quite a good speed.
Yes that sounds feasible, as long as you can get the mechanical arrangement right to prevent slipping.
Have you rejected the usual wire measuring devices?
I missed this:
Anyway, possibly an inductive prox switch could work - sensing the teeth. Or, a photosensor detecting the gaps between the teeth.
Nah..I saw that as well but the lower rollers might break the teeth of the wire.May be this can modified a bit for the application.I wanted something that I can build using Arduino/nodemcu ![]()
That's exactly the thing sir ![]()
Yes,photosensor is a good idea.There's something called ir speed sensor here: https://www.electronicscomp.com/speed-measuring-sensor-groove-coupler-module-arduino?gad_source=1&gclid=CjwKCAjw17qvBhBrEiwA1rU9w-pI6JT-gE0WOgSrppBOGoXQf4uD6jic4iMxYK7UFI6NNdrVQHxTlxoCVooQAvD_BwE
I guess this can be used,not sure if it can measure high speed wire going through it.
This is where datasheets come into play. Calculate how many times per second the light would be blocked/unblocked then find a sensor that can keep up.
