I'm trying to measure EMG signals using an EMG sensor with my Arduino, following the wiring instructions provided by others. However, I'm facing a couple of issues:
The sensor is getting extremely hot.
The measurements are not accurate.
I initially suspected that the battery polarity might be reversed, so I tried connecting the battery with reversed polarity. Unfortunately, this only made the sensor heat up even more.
Has anyone encountered similar issues or can suggest what might be causing these problems? Any advice on troubleshooting or proper wiring would be greatly appreciated.
I don't know exactly which component is being referred to, but if the diagram is incomplete, I don't think I used an EMG amplifier. I didn't use anything other than the equipment shown in that diagram.
Based on the video, it seems that only the devices shown were used to read the signal. Does that mean an amplifier is absolutely necessary? Thank you for your help!
You haven't posted any links to any of the equipment you are using.
The little red module in the drawing is an EMG amplifier, and it has almost certainly been destroyed by miswiring, especially after reversing the battery connections.
