Microduino -- small and stackable Arduino compatible board
Here is my custom designed Arduino board called "Microduino"
the idea is spliting Arduino circuit into two parts: Microduino-Core is MCU part and Microduino-FT232R is for ttl2usb.
two boards can be stacked together through U-shape pinout, the pinout is compatible to hole board, because pin pitch is 0.1inch.
I would like to hear your opinions about it. thank you.
Looks sharp with the white solder mask.
I've done the same with 328s and 1284s with more power & Gnd connections if desired, haven't done a mating USB/Serial adapter yet. Was thinking of doing a power supply module too, but small stuff is really intended to be battery powered, say 3 AA to AAA or a flat 3.7V LiPo.
RS232 module, shift register module, too many ideas to implement. Seems at some point it gets easier & cheaper to spread out vs stackup and not have so many connectors.
http://www.crossroadsfencing.com/BobuinoRev17
That seems like an awesome and useful idea.
Could be, if it suits your need. That's always the key, finding the right part for the job.
Thank you!
you can find more information about Microduino from our facebook Microduino and wiki http://wiki.makermodule.com
Microduino:
Thank you!
you can find more information about Microduino from our facebook Microduino | Westlake Village CA and wiki http://wiki.makemodule.com
Small mistake, the link should be... http://wiki.makermodule.com
Simpson_Jr:
Microduino:
Thank you!
Oh... thank you! I correct it. :slight_smile:
The board looks very pro, Microduino.
aarondc:
Please check more information in my facebook Microduino | Westlake Village CA
i did already. your ks video is almost perfect.
Hooray! Your project, Microduino: Arduino in your pocket--small, stackable, smart, has been accepted!
Finally got approval from Kickstarter! We will launch Microduino at 10AM, 9th/Sep (EST)! Please look forward to!
Check Microduino status in
Facekbook: Microduino
Twitter: http://www.twitter.com/Microduino
Wiki: http://wiki.Microduino.cc
@Mircroduino,
Having purchased some of your cards courtesy of your Kickstarter posting I'm keen to connect these boards to the real world.
Do you have an Eagle library yet of the standard card pin layout that would assist to create some interface cards?
