How do I get this to work ? Wiring from here http://www.workshopshed.com/2012/07/a-little-venture-with-electronics-lcd.html
I can't download library from this site.
This is LCD http://ee.farnell.com/midas/mccog21605b6w-sptlyi/lcd-cog-2x16-stn-grn-b-l-i2c/dp/2063208?Ntt=mccog21605b6w-s
I have Leonardo
Use the library from here
https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
maybe this wiring tutorial is easer to understand:
I don't know what is wrong.Nothing on lcd.
Use the wiring tutorial above, and try to figure out the right pin out of you LCD modifying this part of the code
#define I2C_ADDR 0x27 // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
If you don know the I2C_ADDR, run the following code to find it out:
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// http://www.gammon.com.au/forum/?id=10896
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 120; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
Don't forget to open the Serial Monitor.
LCD pins:
1 VOUT
2 CAP1N
3 CAP1P
4 VDD
5 VSS
6 SDA
7 SCL
8 RST
Datasheet is here http://www.farnell.com/datasheets/1485486.pdf
Tomorrow i scan.
