Millivolt/microvolt measurement
"Measured EMG potentials range between less than 50 μV and up to 30 mV,"
so if you are trying that you will need a much higher gain.
I've never looked at signals from plants, it will be fun to try but you may see electrode potentials.
Again you may need a lot more gain.
Hi again. I get readings now but the values seem to die down.
I am confused as to what is causing this.
From what? How?
A graph without X and Y labelled is no use. Are they volts? microvolts? Amps? Is the Y axis Height? Humidity? Tiime (microseconds or days?)
The Y axis is the Analog readings in Volts after the plant signals have been passed through the amplifier. X axis is the time (each reading is taken in 100 milliseconds).
Hi, @enligio
What are you using as a calibrated signal source for your tests?
Can you please post your circuit?
Can you please post your code?
Tom... :grinning: :+1: :coffee: :australia:
To know what voltage your analog reading corresponds to you will need to calibrate the system.
