Mirror Display On LCDWIKI Library with 2.4 TFT LCD
hi everyone,
I have a TFT LCD 2.4inch that i guess is from a brand called SPI-Flash (or not) this is the only thing written on the back, i have tried everything on any forums, first of all this just works with the libraries named <LCDWIKI_GUI.h> and <LCDWIKI_KBV.h>, not adafruit. second and my only problem is that the texts and everything is sort of mirrored (flipped). i used Set_Rotation(0); and no luck. here is my code and also the display reginfo:
reg(0x0000) 00 00 ID: ILI9320, ILI9325, ILI9335, ...
reg(0x0004) 00 E3 00 00 Manufacturer ID
reg(0x0009) 00 00 61 00 00 Status Register
reg(0x000A) 00 08 Get Power Mode
reg(0x000C) 00 06 Get Pixel Format
reg(0x0061) 00 00 RDID1 HX8347-G
reg(0x0062) 00 00 RDID2 HX8347-G
reg(0x0063) 00 00 RDID3 HX8347-G
reg(0x0064) 00 00 RDID1 HX8347-A
reg(0x0065) 00 00 RDID2 HX8347-A
reg(0x0066) 00 00 RDID3 HX8347-A
reg(0x0067) 00 00 RDID Himax HX8347-A
reg(0x0070) 00 00 Panel Himax HX8347-A
reg(0x00A1) 00 00 00 00 00 RD_DDB SSD1963
reg(0x00B0) 00 00 RGB Interface Signal Control
reg(0x00B4) 00 80 Inversion Control
reg(0x00B6) 00 0A 82 27 04 Display Control
reg(0x00B7) 00 77 Entry Mode Set
reg(0x00BF) 00 02 02 02 02 02 ILI9481, HX8357-B
reg(0x00C0) 00 00 00 00 00 00 00 00 00 Panel Control
reg(0x00C8) 00 00 20 31 42 13 04 00 00 00 00 00 00 GAMMA
reg(0x00CC) 00 06 Panel Control
reg(0x00D0) 00 A4 B2 Power Control
reg(0x00D2) 00 00 00 00 00 NVM Read
reg(0x00D3) 00 00 00 00 ILI9341, ILI9488
reg(0x00D4) 00 00 00 00 Novatek ID
reg(0x00DA) 00 E3 RDID1
reg(0x00DB) 00 00 RDID2
reg(0x00DC) 00 00 RDID3
reg(0x00E0) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-P
reg(0x00E1) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 GAMMA-N
reg(0x00EF) 00 00 00 00 00 00 ILI9327
reg(0x00F2) 00 00 00 00 00 00 00 00 00 00 00 00 Adjust Control 2
reg(0x00F6) 00 00 00 00 Interface Control
*This program is a demo of displaying string
*This demo was made for LCD modules with 8bit or 16bit data port.
*This program requires the the LCDKIWI library.
* File                : display_string.ino
* Hardware Environment: Arduino UNO&Mega2560
* Build Environment   : Arduino
*Set the pins to the correct ones for your development shield or breakout board.
*This demo use the BREAKOUT BOARD only and use these 8bit data lines to the LCD,
*pin usage as follow:
*                  LCD_CS  LCD_CD  LCD_WR  LCD_RD  LCD_RST  SD_SS  SD_DI  SD_DO  SD_SCK
*     Arduino Uno    A3      A2      A1      A0      A4      10     11     12      13
*Arduino Mega2560    A3      A2      A1      A0      A4      10     11     12      13
*                  LCD_D0  LCD_D1  LCD_D2  LCD_D3  LCD_D4  LCD_D5  LCD_D6  LCD_D7
*     Arduino Uno    8       9       2       3       4       5       6       7
*Arduino Mega2560    8       9       2       3       4       5       6       7
*Remember to set the pins to suit your display module!
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, QD electronic SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_KBV.h> //Hardware-specific library
//if the IC model is known or the modules is unreadable,you can use this constructed function
LCDWIKI_KBV mylcd(ILI9341,A3,A2,A1,A0,A4); //model,cs,cd,wr,rd,reset
//if the IC model is not known and the modules is readable,you can use this constructed function
//LCDWIKI_KBV mylcd(240,320,A3,A2,A1,A0,A4);//width,height,cs,cd,wr,rd,reset
//define some colour values
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
int testME = 11111;
  mylcd.Init_LCD();
  mylcd.Set_Rotation(0);
  Serial.println(mylcd.Read_ID(), HEX);
  mylcd.Fill_Screen(BLACK);
  mylcd.Set_Text_Mode(0);
  mylcd.Fill_Screen(0x0000);
  mylcd.Set_Text_Back_colour(BLACK);
  //display 1 times string
  mylcd.Set_Text_colour(RED);
  mylcd.Set_Text_Size(1);
  mylcd.Print_String("Hello World!", 0, 0);
  mylcd.Print_Number_Float(01234.56789, 2, 0, 8, '.', 0, ' ');
  mylcd.Print_Number_Int(0xDEADBEF, 0, 16, 0, ' ',16);
  //mylcd.Print_String("DEADBEF", 0, 16);
  //display 2 times string
  mylcd.Set_Text_colour(GREEN);
  mylcd.Set_Text_Size(2);
  mylcd.Print_String("Hello World!", 0, 40);
  mylcd.Print_Number_Float(01234.56789, 2, 0, 56, '.', 0, ' ');
  mylcd.Print_Number_Int(0xDEADBEF, 0, 72, 0, ' ',16);
  //mylcd.Print_String("DEADBEEF", 0, 72);
  //display 3 times string
  mylcd.Set_Text_colour(BLUE);
  mylcd.Set_Text_Size(3);
  mylcd.Print_String("Hello World!", 0, 104);
  mylcd.Print_Number_Float(01234.56789, 2, 0, 128, '.', 0, ' ');
  mylcd.Print_Number_Int(0xDEADBEF, 0, 152, 0, ' ',16);
 // mylcd.Print_String("DEADBEEF", 0, 152);
  //display 4 times string
  mylcd.Set_Text_colour(WHITE);
  mylcd.Set_Text_Size(4);
  mylcd.Print_String("Hello!", 0, 192);
  //display 5 times string
  mylcd.Set_Text_colour(YELLOW);
  mylcd.Set_Text_Size(5);
  mylcd.Print_String("Hello!", 0, 224);
  //display 6 times string
  mylcd.Set_Text_Size(6);
  mylcd.Print_String("Hello!", 0, 266);
  delay(3000);
You have a regular Mcufriend shield. Please read this associated thread
Where did you get this 0xE300 display. Please post link.
Please ask the shop for manufacturer or datasheet. Then I can support this display "out of the box"
I have no connection with LcdWiki. They never asked to use "kbv" name.
David.
here is the link of seller in my country, it seems other LCD they have are fine but only this one has mirroring problem, they have 7 day return policy but unfortunately i bought it more than 40 days ago and didn't tested it until now.
i saw the tread link you send, before posting this one. any command that i add with hex like this ID = 0xE300 to the code that i have lots of error will come up. and there is something else that i find out today, colors are wrong too, if i give it yellow it is gonna show green, if i use cyan it is gonna show red.
could you give me a code to put in my own code, or tell me where extacly should i put that ID hex, because i took that from serial monitor of arduino IDE
Please ask them for help. Your shop can ask their Wholesale Supplier. The Wholesale Supplier will know the controller.
Shops will only worry about faulty items if it costs them money. e.g. to refund unhappy customers.
If I just released a new version of the MCUFRIEND_kbv library shops would not get any complaints.
So the shop would never email their Wholesale Supplier.
Shops will not reply to me because I am not their customer. (and I do not speak Arabic)
But they should help you because you are a customer.
Meanwhile, follow the instructions from this message
David.
do you build them yourself? because if so i suggest that some of the pins that are not used for LCD are down there and reaching them from the top is not ideal, may be some other ways like not soldering those pins on top of the LCD and letting them be empty can be more useful
for example i wanted to make my dad a very simple project for his little garden with UNO & the LCD and 2 sensors that i had, but the shield took all the top and i soldered them directly to UNO from the bottom of arduino.
if you find solution for that, i have to say with the price tag and options of this component, IT IS THE BEST TFT LCD for DIYs. i few little changes may bring more happy customers :wink: :smiley:
To fix this problem you should go to the LCDWIKI_KBV.cpp file in the line 845 and modify the code according to this:
From
switch (rotation)
		   	case 0:
		     	val = ILI9341_MADCTL_MX | ILI9341_MADCTL_BGR; //0 degree
		   	case 1:
		     	val = ILI9341_MADCTL_MV | ILI9341_MADCTL_BGR; //90 degree
		 	case 2:
		    	val = ILI9341_MADCTL_MY | ILI9341_MADCTL_ML |ILI9341_MADCTL_BGR; //180 degree
		   	case 3:
		     	val = ILI9341_MADCTL_MX | ILI9341_MADCTL_MY| ILI9341_MADCTL_ML | ILI9341_MADCTL_MV | ILI9341_MADCTL_BGR; //270 degree
To
switch (rotation)
		   	case 0:
		     	val = ILI9341_MADCTL_ML | ILI9341_MADCTL_BGR; //0 degree
		   	case 1:
		     	val = ILI9341_MADCTL_MY|ILI9341_MADCTL_MV | ILI9341_MADCTL_BGR; //90 degree
		 	case 2:
		    	val = ILI9341_MADCTL_MY|ILI9341_MADCTL_MX|ILI9341_MADCTL_MH|ILI9341_MADCTL_BGR; //180 degree
		   	case 3:
		     	val = ILI9341_MADCTL_MX | ILI9341_MADCTL_MV | ILI9341_MADCTL_BGR; //270 degree
