Hello there.
First of all, I'm a newbie.
I have a mjkdz I2C board and a LCD (+arduino, of course). The LCD pins are {VSS, VDD, VD0, RS, RW, E, D0, D1, D2, D3, D4, D5, D6, D7, A, K} in this order. The I2C circuit is connected to LCD like this: 1-VSS, 2-VDD, 3-VD0......16-K (when the soldering is a square, that means that pin is the first pin, right?)
https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/schematics#
Here says an order for my I2C circuit. But in my opinion, if the I2C is connected to LCD how I said upper, the order from there is wrong.
The constructor would not be LiquidCrystal_I2C lcd(0x20, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE);.
It will be LiquidCrystal_I2C lcd(0x20, 6, 5, 4, 11, 12, 14, 14, 15, NEGATIVE);
The trouble is that none of the two lines of code do not work. The LCD only has backlight and 16 squares on the first line.
Any help would be very appreciated.
