MKR IoT Carrier capacitive touch sensor not working
Hi, I'm trying out the capacitive touch buttons on my MKR IoT carrier, and the TOUCH0 or the first touch button is not working. I tried the other touch buttons, and they work fine. I looked through the Arduino articles https://support.arduino.cc/hc/en-us/articles/360021222000 to diagnose any hardware issues, and it seems there are none (as the serial plotter shows activity when the TOUCH0 is being pressed). I looked through https://support.arduino.cc/hc/en-us/articles/360021221980-Calibrating-the-MKR-IoT-Carrier-capacitive-buttons to try to calibrate the buttons next and the first touch button still doesn't work.
I am using the carrier with plastic encasing.
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
  carrier.withCase();
  carrier.begin();
  carrier.Button0.updateConfig(0);
  carrier.Buttons.update();
  // Checks if button 00 is touched
  if (carrier.Buttons.getTouch(TOUCH0))
    Serial.println("Button 1 pressed down");
    carrier.leds.setPixelColor(0, 255, 0, 0);
    carrier.leds.setBrightness(255);
    carrier.leds.show();
    carrier.leds.setBrightness(0);
The code above is what I've tried to run, running it with from TOUCH1 through TOUCH4 works perfectly fine, but TOUCH0 is causing an issue. It can't be a hardware issue since the button responded to the analogRead (in the first article), it just doesn't respond to the built in functions.
Kindly appreciate any help, thanks.
