So I am trying to send a serial command from my computer to my MKRZero.
i have C# code written which opens the COM port sends a ''1" then the MKRZero should move a servo and bring a pin high.
I think there must be something wrong with my Setup() or its my C# code
i have read something about Serial1 being used, but I'm not sure if that applies here or how to use it.
This program ran great on an Arduino UNO
Arduino Code:
#include <Servo.h>
#define BIGSERVOSW 5
#define EXTRASERVOSW 4
#define ROCK1 2
#define ROCK2 3
#define ROCKETFIRE1 12
#define ROCKETFIRE2 11
#define LED 10
Servo DoorServo;
Servo servo2;
Servo servo3;
char c;
String cmd = "";
pinMode(BIGSERVOSW, INPUT);
pinMode(EXTRASERVOSW, INPUT);
pinMode(ROCK1, INPUT);
pinMode(ROCK2, INPUT);
pinMode(ROCKETFIRE1, OUTPUT);
pinMode(ROCKETFIRE2, OUTPUT);
pinMode(LED,OUTPUT);
DoorServo.attach(7);
servo2.attach(6);
servo3.attach(9);
// LETS PULL UP THE INPUTS
digitalWrite(BIGSERVOSW, HIGH);
digitalWrite(EXTRASERVOSW, HIGH);
digitalWrite(ROCK1, HIGH);
digitalWrite(ROCK2, HIGH);
DoorServo.write(0);
servo2.write(0);
servo3.write(0);
while (!Serial){;}
digitalWrite(ROCKETFIRE1, LOW); //get back to default
digitalWrite(ROCKETFIRE2, LOW); //get back to default
digitalWrite(LED, LOW);
getSerial();
// Check for bigservo switch
if ( digitalRead(BIGSERVOSW) == LOW || cmd == "5")
/* according to "Then a Separate servo with its own button when pressed
moves a Large servo 120 degrees then returns when you let of the button" */
servo2.write(0); //bring servo back to 0
servo2.write(120);
Serial.println(" BIGSERVO 120deg arrived " );
delay(500); //for debounce
else if ( digitalRead(ROCK1) == LOW || cmd == "1")
Serial.println(" ROCK1 pressed" );
DoorServo.write(95); // open the door for 95 deg
while( DoorServo.read() != 95) //do nothing till servo come to 95
delay(1000); // dealy for 1 sec
digitalWrite(ROCKETFIRE1, HIGH); //fire the rocket 1
delay(2000); //delay for 2 sec
DoorServo.write(0); // close the door again 0deg
while( DoorServo.read() != 0) //do nothing till servo come to 0
Serial.println(" Door closed" );
cmd = "";
there is 2 getSerial(). one after void loop and one at the end under void
#include <Servo.h>
#define ROCK1 2
#define ROCK2 3
#define LED 10
Servo DoorServo;
Servo servo2;
Servo servo3;
char c;
String cmd = "";
servo2.attach(6);
servo3.attach(9);
DoorServo.write(0);
servo2.write(0);
servo3.write(0);
while (!Serial){;}
getSerial();
servo2.write(120);
cmd = "";
void getSerial(){
cmd = "";
if(Serial.available()>0){
cmd = "";
c = Serial.read();
cmd = c;
while(Serial.available()>0){
cmd.concat((char)Serial.read());
the code works on my UNO, so the c# program is fine. unless the mkrzero if setup different. that's what I need to know. what do I need to change to make the mkrzero work?
here is my whole program indented better for you
#include <Servo.h>
#define ROCK1 2
#define ROCK2 3
#define LED 10
Servo DoorServo;
Servo servo2;
Servo servo3;
char c;
String cmd = "";
pinMode(LED, OUTPUT);
servo2.attach(6);
servo3.attach(9);
DoorServo.write(0);
servo2.write(0);
servo3.write(0);
while (!Serial);
// put your main code here, to run repeatedly
getSerial();
servo2.write(120);
while ( DoorServo.read() != 95) //do nothing till servo come to 95
while ( DoorServo.read() != 0) //do nothing till servo come to 0
cmd = "";
else if ( digitalRead(ROCK2) == LOW || cmd == "2" )
Serial.println(" ROCK2 pressed" );
Serial.println(" Door opened" );
digitalWrite(ROCKETFIRE2, HIGH); //fire the rocket 1
cmd = "";
else if ( digitalRead(EXTRASERVOSW) == LOW || cmd == "3")
servo3.write(0); //bring servo back to 0
servo3.write(120);
Serial.println(" ExtraServo 120deg arrived " );
if ( digitalRead(LED) == HIGH || cmd == "6" )
digitalWrite(LED, HIGH);
if ( digitalRead(LED) == LOW || cmd == "8" )
if (digitalRead(ROCKETFIRE1) == HIGH || cmd == "7" ) //THIS IS THE FULL ASSAULT PROGRAM FIRING A LOT OF WEAPONS. VOICE ONLY.
digitalWrite(ROCKETFIRE2, HIGH); //fire the rocket 2
delay(1500); //delay for 2 sec
digitalWrite(ROCKETFIRE2, LOW); // get back to default
delay(2000);
cmd = "";
void getSerial() {
cmd = "";
if (Serial.available() > 0) {
cmd = "";
c = Serial.read();
cmd = c;
while (Serial.available() > 0) {
