mma7361 with stepper motor
Hi all,
I'm using an accelerometer mma7361 reading an angle of rotation and using this angle to make my stepper motor rotate a set number of rotations.
Here is my code:
#include <Stepper.h>
int analog_x;
float vol_x;
float add_x;
float g_x;
float degree_x;
int switchPin1 = 2;
int switchPin2 = 4;
int switchPin3 = 7;
const int stepsPerRevolution = 20;  // change this to fit the number of steps per revolution
                                     // for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
int rotate(int num_rot);
 pinMode(switchPin1, INPUT);
 pinMode(switchPin2, INPUT);
 pinMode(switchPin3, INPUT);
 myStepper.setSpeed(1000);
 if(digitalRead(switchPin1)==0){
 analog_x=analogRead(0);
  vol_x=analog_x*5.0/1024;//convert analog_x-->voltage value(v)
  add_x=vol_x-1.62;//calculate the added x axis voltage value
  g_x=add_x/0.8;//calculate the gram value
  if(g_x<=1&&g_x>=-1) //We use this condition to prevent the overflow of asin(x).( If x>1 or x<-1, asin(x)=0)
  degree_x=asin(g_x)*180.0/PI;//calculate the degree value
if (digitalRead(switchPin1)==1)  {
  degree_x=0;
  //fix the overflow condition
  if(g_x>1)
  degree_x=90;
    if(g_x<-1)
  degree_x=-90;
if(digitalRead(switchPin1)==1 && digitalRead(switchPin2)==0 && digitalRead(switchPin3)==0 && 0 <= degree_x < 5)
  rotate(3);
if(digitalRead(switchPin1)==1 && digitalRead(switchPin2)==0 && digitalRead(switchPin3)==0 && 25 <= degree_x < 30)
  rotate(5);
 //print
  Serial.print("Read switch input1: ");
  Serial.print(digitalRead(switchPin1));
  Serial.print("\t");
Serial.print("\t");
  Serial.print("Read switch input2: ");
  Serial.print(digitalRead(switchPin2));
  Serial.print("\t");
Serial.print("\t");
  Serial.print("Read switch input3: ");
  Serial.print(digitalRead(switchPin3));
  Serial.print("\t");
Serial.print("\t");
  Serial.print("x1:");
  Serial.print(degree_x);
  delay(200);
  for(int i = 0 ; i < 10 ; i++)
    for(int i = 0 ; i < num_rot ; i++)
      myStepper.step(20);
  return 1;
now I'm certain that:
  1. I can read an angle and save it in a variable (degree_x)
  2. the function called int rotate(num_rot) works. if input is 5 the motor rotates 5 or maybe 6 but this is not a problem.
    3)switch buttons work prefectly
  3. motor and mma7361 connections are correct(checked each individually)
    5)I've checked certain parts of the code alone and they seem to work properly
now the problem is the following:
in my general if statement condition
if(digitalRead(switchPin1)==1 && digitalRead(switchPin2)==0 && digitalRead(switchPin3)==0 && ?? <= degree_x < ??)
the degree_x is the problem!
first if i have the same combination of inputs for the switch buttons the angle (degree_x)doesn't make a difference, in other words in my previous provided code the motor first rotates 3 times then 5 times regardless of degree_x. The moment I press the button the motor starts rotating, completes the rotations then stops!
I have even tried this with no switch buttons but the same happens! the motor rotates every time i call the function rotate, regardless if the angle degree_x in the condition is met or not!
second to that the moment the motor starts rotating the value of degree_x changes unbelievably, for example if it was
5+- .5 once the motor rotates it becomes 40+- .5 and does not go down at all until I re-upload the sketch!
does anybody have an explanation or better a solution!
pls I need help!
 0 <= degree_x  <  5
That expression doesn't do what you probably expect it to do. It is NOT a shorthand for:
0 <= degree_x && degree_x < 5
It really means:
 (0 <= degree_x)  <  5
Since (0 <= degree_x) is a boolean expression resulting in 0 or 1 it will ALWAYS be less than 5.
