Modbus Slave with PC simulator as master NEED HELP URGENTLY
Hi friends,
I am trying to make project on modbus protocol, I read almost all forums and posted my querry over there, but I didn't got answer so I am opening new topic.
WHAT I WANT TO DO
I want to make modbus master and slave, which will work with each other or with simulating software with function 3,6,16.
WHAT I AM USING
I am using arduino UNO pair for aster and slave.
For software simulator I am using simply modbus slave and master v8.0
Communication with computer through RS485 protocol.
What I achieved
I tried on this topic from few days, following are the things which I manage to run the circuit with program on proteus properly with no fail attempts.
What I AM USING
I am using following master and slave programs.
MASTER
#include <SimpleModbusMaster_DUE.h>
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 6, 5, 4, 3);
   The example will use packet1 to read a register from address 0 (the adc ch0 value)
   from the arduino slave (id=1). It will then use this value to adjust the brightness
   of an led on pin 9 using PWM.
   It will then use packet2 to write a register (its own adc ch0 value) to address 1
   on the arduino slave (id=1) adjusting the brightness of an led on pin 9 using PWM.
long previousMillis = 0;
long interval = 1000;
//////////////////// Port information ///////////////////
#define baud 9600
#define timeout 3000
#define polling 100// the scan rate
#define retry_count 10
// used to toggle the receive/transmit pin on the driver
#define TxEnablePin 2
#define LED 9
// The total amount of available memory on the master to store data
#define TOTAL_NO_OF_REGISTERS 3
// This is the easiest way to create new packets
// Add as many as you want. TOTAL_NO_OF_PACKETS
// is automatically updated.
enum
  PACKET1,
  PACKET2,
  PACKET3,
  TOTAL_NO_OF_PACKETS // leave this last entry
// Create an array of Packets to be configured
Packet packets[TOTAL_NO_OF_PACKETS];
// Masters register array
unsigned int regs[TOTAL_NO_OF_REGISTERS];
unsigned int check,check1;
  // Initialize each packet
  modbus_construct(&packets[PACKET1], 1, READ_HOLDING_REGISTERS, 0, 1, 0);
  modbus_construct(&packets[PACKET2], 1, PRESET_MULTIPLE_REGISTERS, 1, 1, 0);
 // modbus_construct(&packets[PACKET1], 1, READ_INPUT_STATUS, 0, 1, 0);
  //modbus_construct(&packets[PACKET2], 1, FORCE_SINGLE_COIL, 5, 1, 1);
  //modbus_construct(&packets[PACKET3], 1, FORCE_SINGLE_COIL, 5, 1, 1);
  // Initialize the Modbus Finite State Machine
  modbus_configure(&Serial, baud, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
  pinMode(LED, OUTPUT);
  lcd.begin(16, 2);
  modbus_update();
  regs[0] = analogRead(0); // update data to be written to arduino slave
  check = analogRead(A0);
  analogWrite(LED, regs[1]>>2); // constrain adc value from the arduino slave to 255
check1=regs[1];
  if (currentMillis - previousMillis >= interval)
    if (regs[0] == COIL_ON)
      regs[0] = COIL_OFF;
      regs[0] = COIL_ON;
  lcd.clear();
  lcd.print(check1);
  delay(50);
  /*if (regs[0] & 0x0001 == 1)
    regs[1] = COIL_ON;
    regs[1] = COIL_OFF;
Slave
#include <SimpleModbusSlave_DUE.h>
   SimpleModbusSlaveV10_DUE supports function 3, 6 & 16.
   This example code will receive the adc ch0 value from the arduino master.
   It will then use this value to adjust the brightness of the led on pin 9.
   The value received from the master will be stored in address 1 in its own
   address space namely holdingRegs[].
   In addition to this the slaves own adc ch0 value will be stored in
   address 0 in its own address space holdingRegs[] for the master to
   be read. The master will use this value to alter the brightness of its
   own led connected to pin 9.
   The modbus_update() method updates the holdingRegs register array and checks
   communication.
   Note:
   The Arduino serial ring buffer is 64 bytes or 32 registers.
   Most of the time you will connect the arduino to a master via serial
   using a MAX485 or similar.
   In a function 3 request the master will attempt to read from your
   slave and since 5 bytes is already used for ID, FUNCTION, NO OF BYTES
   and two BYTES CRC the master can only request 58 bytes or 29 registers.
   In a function 16 request the master will attempt to write to your
   slave and since a 9 bytes is already used for ID, FUNCTION, ADDRESS,
   NO OF REGISTERS, NO OF BYTES and two BYTES CRC the master can only write
   54 bytes or 27 registers.
   Using a USB to Serial converter the maximum bytes you can send is
   limited to its internal buffer which differs between manufactures.
#define  LED 13
// Using the enum instruction allows for an easy method for adding and
// removing registers. Doing it this way saves you #defining the size
// of your slaves register array each time you want to add more registers
// and at a glimpse informs you of your slaves register layout.
//////////////// registers of your slave ///////////////////
enum
  // just add or remove registers and your good to go...
  // The first register starts at address 0
  ADC_VAL,
  PWM_VAL,
  HOLDING_REGS_SIZE // leave this one
  // total number of registers for function 3 and 16 share the same register array
  // i.e. the same address space
unsigned int holdingRegs[HOLDING_REGS_SIZE]; // function 3 and 16 register array
unsigned int check;
  /* parameters(HardwareSerial* SerialPort,
                long baudrate,
                unsigned char ID,
                unsigned char transmit enable pin,
                unsigned int holding registers size,
                unsigned int* holding register array)
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  modbus_configure(&Serial, 9600, 1, 2, HOLDING_REGS_SIZE, holdingRegs);
  // modbus_update_comms(baud, id) is not needed but allows for easy update of the
  // port variables and slave id dynamically in any function.
  modbus_update_comms(9600, 1);
  // modbus_update() is the only method used in loop(). It returns the total error
  // count since the slave started. You don't have to use it but it's useful
  // for fault finding by the modbus master.
  modbus_update();
  holdingRegs[ADC_VAL] = analogRead(A0); // update data to be read by the master to adjust the PWM
  analogWrite(LED, holdingRegs[PWM_VAL]>>2); // constrain adc value from the arduino master to 255
  check=holdingRegs[PWM_VAL];
  lcd.clear();
  lcd.print(check);
  delay(30);
  /* Note:
     The use of the enum instruction is not needed. You could set a maximum allowable
     size for holdinRegs[] by defining HOLDING_REGS_SIZE using a constant and then access
     holdingRegs[] by "Index" addressing.
     I.e.
     holdingRegs[0] = analogRead(A0);
     analogWrite(LED, holdingRegs[1]/4);
With attached schematics.
Creating second post as it is exceeding maximum character limit!
CONTINUING from !st post
Now to get proper debugging I am using simulator instead of Uno pair (simulator as master and UNO as slave)
Now I am able to get the frame from master simulator to my arduino. I check that using SERIAL LCD display program
  LiquidCrystal Library - Serial Input
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch displays text sent over the serial port
 (e.g. from the Serial Monitor) on an attached LCD.
 The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystalSerial
// include the library code:
int check;
  lcd.begin(16, 2);
  // initialize the serial communications:
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    delay(20);
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (Serial.available() > 0) {
      // display each character to the LCD
      lcd.print(Serial.read());
      //check = Serial.read();
      //Serial.print("check");
now I am getting same data which I am getting on proteus (My proteus code is running)
Means my slave arduino is receiving proper data from simulator software
But now on proteus my slave arduino is responding finely but in hardware he is not giving any response also he is not getting any value in holdingRegs[PWM_VAL]. but on proteus I can.
I checked my serial transmission with other serial program it is responding properly.
I also tried some other modbus program for slave such as
#include <ModbusRtu.h>
// data array for modbus network sharing
uint16_t au16data[16] = {
  3, 1415, 9265, 4, 2, 7182, 28182, 8, 0, 0, 0, 0, 0, 0, 1, -1 };
 *  Modbus object declaration
 *  u8id : node id = 0 for master, = 1..247 for slave
 *  u8serno : serial port (use 0 for Serial)
 *  u8txenpin : 0 for RS-232 and USB-FTDI
 *               or any pin number > 1 for RS-485
Modbus slave(1,0,0); // this is slave @1 and RS-232 or USB-FTDI
  slave.begin( 19200 ); // baud-rate at 19200
  slave.poll( au16data, 16 );
And it is giving all attempts successful( but it only execute fun 3)! Means my hardware looks ok!
I am not understanding why my ARDUINO is unable to process receive data.
Same happens when I try as arduino as master my arduino is able to transfer proper frame and my simulator respond to that frame but again my master don't process it and don't display the data on LCD!
( and everything runs awesomely on proteus)
Can any one help me on this?
Any help will be appreciated
Thanks!
Yatin
