I recently bought a module sim 808 and I need to do a project with it.
The problem here is that when I press the powerbutton the second led is not powering on, the first led from the power supply is lit, only the second led is not powering on, no matter how many seconds I pressed the power button.
I am powering the module with a 9V battery but I don´t know the amperage, I don´t know if this is the reason of why is not powering on.
Most modem's use significant current. Try powering via USB.
From the datasheet for the SIM808.
"The transmitting burst will cause voltage drop and the power supply must be able to provide sufficient current up to 2A."
from what I can find looks like it has the following specs...
High efficient LDO power supply, the input voltage is 5--26V. note to the that when the input voltage is less than 9V. Please ensure that the power supply can provide 2a of the current. another power supply port 3.5--4.2V input (suitable for lithium battery power supply).
Just be aware that it won't last long. An alkaline 9v battery can deliver about 500mAh... and that device can pull 2000 mA ... so you should look for something with a bigger capacity.
