Post your annotated schematic, not a frizzy and include links to technical information on all the hardware devices. Posting your code will also help. Read the specifications on the motor driver you chose, it will just get hot and fry. Also determine what batteries yo will need. I have a feeling you fried the motor shield. Each motor requires: 28 watts at 6 volts. That works out at (28/6) *4 = 18.4 Amps.
I tried that firmware upgrade too, but my pc didnt detect the shield.
Beside that, do you have any other solution to control the motors with a d1 mini? It has not to be exactly that shield. What would you use for something like that?
hello, sorry if this is not helping because i'm a noob to here
but , from what i know , in the void setup you have to define or add the pinMode to output no ?
