Motor shield rev3
Hi i wanted to connect a servo motor to MSREV3 , but both 3pin inputs are not working , when i connect the servo through + - and pin 10 it reads the code :neutral_face:
Any idea about it
ā€œI cut the connection on vcc in the board previously
What is MSREV3?
Maybe you have accidentally damaged the board when cutting the VCC connection. If the 3-pin inputs aren't working, it could indicate a hardware issue.
