Motor & worm gear calculations
Dear all,
Here i wanted to go from basic. I need basic steps to calculate or choose proper wormgear & motor for solar tracking application.
If someone can guide me necessary formula & parameter required to calculate the worm gear box . i have already discuss this topic earlier but not posted in in right thread & i didn't get response
http://www.sunflowerenergyinc.com/Slewing_Drive_-_032511_-_REV.03.pdf
calculation formula required:
  1. torque Vs speed relation for motor & worm gear
  2. torque Vs load for motor & worm gear
  3. Input power & output power for motor & worm gear
    4)turns ratio relationship with motor & worm gear.
I know these are basic question but some tracker design taking kinematic calculation for this.
so if some one can guide with proper resource it will be more help full.
AMPS-N:
I would use the brute-force method. Buy a big motor! If that won't move the device, buy a bigger one.
What about a used car windscreen wiper motor?
...R
I have these realtionship with worm gear Box. I need standard method or assumption to choose to calculate motor & specification.
efficiency= (output Power of Worm gear/ Input Power of WormGear) = Po/Pinput
Output power =P0=(2piOutputspeed*outputtorque)/60
Output power in Kw
Outputspeed in rev/min
outputtorque in Nm
Input power = Pinput=(2piInput speed*Input torque)/60
Output power in Kw
Input speed in rev/min
Input torque in Nm
Net Torque= Toutput+TInput+Tholding =0
These are basic equation followed usually
In order to drive 250Kw plant ; assume 15kw per row I have 16 rows with 1 column.
Worm gear has to Drive 16 rows with coupling with single column item
each panel weighs 20Kg ; 60 panel per row-> 60*20kg=1200Kg
Each row structural weight around = 700Kg
Net weight alone = 1900Kg per Row
so load on worm gear might be 1900*16=30400
Now how can i consider above assumption for motor drive selection
You're out by a factor of 1000!
power = torque * angular-velocity
torque in Nm
angular-velocity in rad/sec
power in watts (NOT kW)
AMPS-N:
There isn't one, torque and speed are independent for a DC motor,
the voltage or PWM duty cycle determines the speed, the torque is
proportional to the load torque.
When I say there isn't one, I mean the load sets this relationship, not
the motor/gear
  1. torque Vs load for motor & worm gear
The torque is the load!
  1. Input power & output power for motor & worm gear
This has been covered, you can perhaps expect ~50% efficiency for a worm
gear due to the high friction levels
What turns? This isn't a transformer. Tooth ratio maybe, most
(but not all) worm gears are single tooth (single helix), so the ratio
is just the number of teeth in the spur gear.
Example working:
You want 300Nm torque at 0.1 rad/sec (1 rpm) via a 60:1 worm
reduction gear.
Input torque = 300/60 = 5Nm, input angular velocity = 0.1*60 = 6 rad/s (60rpm)
BUT that assumes 100% efficiency, so actually more like 10Nm torque needed.
In this example you clear need more reduction gearing since most motors are
1000's of rpm and < 1Nm
10Nm at 6 rad/s = 60 watts mechanical, ie about 80 to 100W electrical to the
motor terminals.
BTW 300Nm is a stupidly large value, this is only an example of the maths.
