Motors not running
This is a long shot because its a super long code file but can someone please explain why my code is not making the motors run?
All components run independently. Merged code and it stopped running.
// Load Libraries
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//#include <Button.h>
#include <TimerOne.h>
#include <Encoder.h>
// Create class
#define OLED_RESET -1
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
Adafruit_MPU6050 mpu;
#define calibButton 5
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// SDA 20
// SCLK 21
#define NPN_PIN 11
// Rotary Encoder Inputs
#define RE_1_outputCLK 2 // RE = Rotary Encoder
#define RE_1_outputDT 3  // RE = Rotary Encoder
#define RE_2_outputCLK 8 // RE = Rotary Encoder
#define RE_2_outputDT 9  // RE = Rotary Encoder
#define ForwardOrReverseButton 6 //only engages reverse when button is activated (LOW; pressed in)
#define Motor1Direction 4 // Motor Direction Control Pin with PWM
#define Motor2Direction 10 // Motor Direction Control Pin with PWM
#define Motor1Speed 12 // Blue wire, PWM
#define Motor2Speed 13 // Green wire, PWM
int RE_1_counter = 0; // Increment counter on the rotary encoder for motor 1
int RE_2_counter = 0; // Increment counter on the rotary encoder for motor 2
int RE_1_State; // RE Rotation Counter on motor 1
int RE_1_LastState; // RE Rotation Memory Location on motor 2
int RE_2_State; // RE Rotation Counter on motor 1
int RE_2_LastState; // RE Rotation Memory Location on motor 2
int NoSpeed = 0;          // No motor speed
int PauseBeforeCountingOnEncodersResumes = 2000;
int clickNum = 360;
const int trigger = 15, calTrigger = trigger * 8;// Basic rotary encoders for Arduino are 30 steps per rev; 1/4 turn
String currDir1 ="", prevDir1 ="Idle", mode = "Calibration";
String currDir2 ="", prevDir2 ="Idle", calib1 = "No", calib2 = "No";
int mainWheelRadiusIn = 24; // In
float mainWheelRadiusM = mainWheelRadiusIn * 0.254; // Meters
float angle1;
float angle2;
unsigned long currMillis, startTime1, finalTime1, currDur1, btDur1, totDur1;
unsigned long startTime2, finalTime2, currDur2, btDur2, totDur2;
const long pauseDuration = 2000; // Miliseconds
const long motorInterval = 3000; // Milliseconds
float angAcceli1, angAccelm1, angAccelf1, angVelf1, avgAngAccel1;
float angAcceli2, angAccelm2, angAccelf2, angVelf2, avgAngAccel2;
float maxUserSpeed1 = 1.7, currUserSpeed1, speedRatio1;
float maxUserSpeed2 = 1.7, currUserSpeed2, speedRatio2;
int maxMotorSpeedFw1 = 50, maxMotorSpeedRv1 = 25, currMotorSpeed1, currMotorSpeed2;
int maxMotorSpeedFw2 = maxMotorSpeedFw1, maxMotorSpeedRv2 = maxMotorSpeedRv1;
// Vars for Sensor Data
sensors_event_t a, g, temp;
const int numSamples = 1000; // Number of samples to collect for calibration
const int calibrateDelay = 10; // Delay in milliseconds between samples
float axOffset = 0, ayOffset = 0, azOffset = 0; // Calibration offsets for accelerometer
float axCalibrated = 0, ayCalibrated = 0, azCalibrated = 0;
double tiltX = 0, tiltY = 0, tiltZ = 0;
const unsigned long motorDuration = motorInterval; // Adjust the duration as needed; used to be 3000
//motorDuration defines how long the motors can run in one direction
float maxTilt = 10;
Encoder encoder1(RE_1_outputCLK, RE_1_outputDT);
Encoder encoder2(RE_2_outputCLK, RE_2_outputDT);
// Define the states for your state machine
enum MotorState {
  IDLE,
  MOTOR1_FORWARD,
  MOTOR1_REVERSE,
  MOTOR2_FORWARD,
  MOTOR2_REVERSE
// Motors have no speed or direction, the motors are stationary
// initial set up state
MotorState motor1State = IDLE;
MotorState motor2State = IDLE;
void calibrateMPU(){
  float axSum = 0, aySum = 0, azSum = 0;
  robojaxText("Calibrating MPU6050. Please keep the sensor still...", 4, 3, 1,true);
  delay(calibrateDelay); // Initial delay before starting calibration
  for (int i = 0; i < numSamples; i++) {
    // Get new sensor events with the readings
	  mpu.getEvent(&a, &g, &temp);
    axSum += a.acceleration.x;
    aySum += a.acceleration.y;
    azSum += a.acceleration.z;
  axOffset = axSum / numSamples;
  ayOffset = aySum / numSamples;
  azOffset = azSum / numSamples;
  robojaxText("MPU Calibration complete!",4,3,1,true);
  delay(2000);
void getMPUData(){
  axCalibrated = a.acceleration.x - axOffset;
  ayCalibrated = a.acceleration.y - ayOffset;
  azCalibrated = a.acceleration.z - azOffset;
  tiltX = atan2(ayCalibrated, azCalibrated) * (180.0 / PI);
  tiltY = atan2(axCalibrated, azCalibrated) * (180.0 / PI);
  tiltZ = atan2(ayCalibrated, axCalibrated) * (180.0 / PI);
void switchPanel(){
  // Write to the NPN transistor
  float duty = 0.5;
  Timer1.pwm(NPN_PIN, duty*1023);
  analogWrite(NPN_PIN, duty*255);   //input pwm signal to switch to the transistor
  //Read Voltage
  float vA0 = analogRead(A0);
  float vOut = vA0 * 5.0 / 1023.0 * (5.0 + 1.0) / 1.0; //voltage read calculation
void resetCounter1(){
  if(mode == "Calibration"){
    if ((abs(RE_1_counter) >= calTrigger) || (currDir1 != prevDir1) || (btDur1 >= pauseDuration)){
      RE_1_counter = 0;
  return;
  if ((abs(RE_1_counter) >= trigger) || (currDir1 != prevDir1) || (btDur1 >= pauseDuration)){
    RE_1_counter = 0;
  return;
void resetCounter2(){
    if ((abs(RE_2_counter) >= calTrigger) || (currDir2 != prevDir2) || (btDur2 >= pauseDuration)){
      RE_2_counter = 0;
  return;
  if ((abs(RE_2_counter) >= trigger) || (currDir2 != prevDir2) || (btDur2 >= pauseDuration)){
    RE_2_counter = 0;
  return;
float getAngAccel(){
  getMPUData();
  // Calculation
  float angAccel = axCalibrated / mainWheelRadiusM;
  return angAccel;
float getAngVel( float angAccel, float finalAng){
  float angVel = sqrt(2 * angAccel * (finalAng));
  return angVel;
float getLinVel(float angVel, float mainWheelRadiusM){
  float linVel = angVel * mainWheelRadiusM;
  return linVel;
 * robojaxText(String text, int x, int y,int size, boolean d)
 * text is the text string to be printed
 * x is the integer x position of text
 * y is the integer y position of text
 * z is the text size, 1, 2, 3 etc
 * d is either "true" or "false". Not sure, use true
void robojaxText(String text, int x, int y,int size, bool d) {
  display.setTextSize(size);
  display.setTextColor(WHITE,BLACK);
  display.setCursor(x,y);
  display.println(text);
  if (d){
    display.display();
    display.fillScreen(BLACK);
void readTime(){
  // Read time
  currMillis = millis();
  btDur1 = currMillis - finalTime1;
  currDur1 = currMillis - startTime1;
  totDur1 = finalTime1 - startTime1;
  btDur2 = currMillis - finalTime2;
  currDur2 = currMillis - startTime2;
  totDur2 = finalTime2 - startTime2;
void calibrateEncoders(){
  readTime();
  // Read the current state of CLK
	RE_1_State = digitalRead(RE_1_outputCLK);
  if (RE_1_State != RE_1_LastState){
	  // If the DT state is different than the CLK state then
	  // the encoder is rotating CCW so decrement
	  if (digitalRead(RE_1_outputDT) != RE_1_State) {
  		RE_1_counter --;
	 		currDir1 ="Backward";
    else {
  		// Encoder is rotating CW so increment
	 		RE_1_counter ++;
	  	currDir1 ="Forward";
    angle1 = RE_1_counter * (360.00 / clickNum);
    if (currDir1 != prevDir1){
      startTime1 = currMillis;
      angAcceli1 = getAngAccel();
      finalTime1 = startTime1;
    if (RE_1_counter == (calTrigger/2)){
      angAccelm1 = getAngAccel();
    else if (RE_1_counter <= (calTrigger)){
      finalTime1 = currMillis;
      angAccelf1 = getAngAccel();
      avgAngAccel1 = (angAcceli1 + angAccelf1 + angAccelm1) / 3;
      angVelf1 = getAngVel(avgAngAccel1, angle1);
      maxUserSpeed1 = getLinVel(angVelf1, mainWheelRadiusM);
      calib1 = "Yes";
    else if (currDir1 == "Backwards" && prevDir1 == "Backwards"){
      robojaxText("Please try again. Push Forward.",4,3,1,true);
      delay(2000);
      RE_1_counter = calTrigger + 2;
      resetCounter1();
    else if (btDur1 >= pauseDuration) {
      robojaxText("Please try again...",4,3,1,true);
      delay(2000);
      RE_1_counter = (calTrigger + 1);
      resetCounter1();
    else {
      robojaxText("Keep going!",4,3,1,true);
    // Put in a slight delay to help debounce the reading
    delay(10);
    resetCounter1();
  // Remember last CLK state
  RE_1_LastState = RE_1_State;
  prevDir1 = currDir1;
  readTime();
	RE_2_State = digitalRead(RE_2_outputCLK);
  if (RE_2_State != RE_2_LastState){
	  if (digitalRead(RE_2_outputDT) != RE_2_State) {
  		RE_2_counter --;
	 		currDir2 ="Backward";
    else {
	 		RE_2_counter ++;
	  	currDir2 ="Forward";
    angle2 = RE_2_counter * (360.00 / clickNum);
    if (currDir2 != prevDir2){
      startTime2 = currMillis;
      angAcceli2 = getAngAccel();
      finalTime2 = startTime2;
    if (RE_2_counter == (calTrigger/2)){
      angAccelm2 = getAngAccel();
    else if (RE_2_counter <= (calTrigger)){
      finalTime2 = currMillis;
      angAccelf2 = getAngAccel();
      avgAngAccel2 = (angAcceli2 + angAccelf2 + angAccelm2) / 3;
      angVelf2 = getAngVel(avgAngAccel2, angle2);
      maxUserSpeed2 = getLinVel(angVelf2, mainWheelRadiusM);
      calib2 = "Yes";
    else if (currDir2 == "Backwards" && prevDir2 == "Backwards"){
      delay(2000);
      RE_2_counter = calTrigger + 2;
      resetCounter2();
    else if (btDur2 >= pauseDuration) {
      delay(2000);
      RE_2_counter = (calTrigger + 1);
      resetCounter2();
    else {
    delay(10);
    resetCounter2();
  RE_2_LastState = RE_2_State;
  prevDir2 = currDir2;
  if((calib1 == "Yes") && (calib2 == "Yes")){
    mode = "Drive";
void calibration() {
  for (int i = 5; i >= 0; --i){
    robojaxText("Calibrating MPU, Keep still in",4,3,1,false);
    robojaxText(String(i), 4, 21, 1, true);
  calibrateMPU();
  robojaxText("Please Push Forward as hard as you can...", 4, 3, 1, true);
  calib1 = "No";
  calib2 = "No";
  while (mode == "Calibration"){
    calibrateEncoders();
  resetCounter1();
  return;
void willMotorStart(){
  readTime();
	// If last and current state of CLK are different, then pulse occurred
	// React to only 1 state change to avoid double count
			RE_1_counter --;
    else {
			RE_1_counter ++;
			RE_2_counter --;
    else {
			RE_2_counter ++;
  if (abs(RE_1_counter - RE_2_counter) >= (trigger*2))
    mode == "Turn";
  else if (RE_1_counter == abs(trigger/2)){
  else if (RE_1_counter <= abs(trigger)){
    currDir1 = 'Idle';
    resetCounter1();
  if (RE_1_counter >= trigger)
    currUserSpeed1 = getLinVel(angVelf1, mainWheelRadiusM);
    speedRatio1 = currUserSpeed1 / maxUserSpeed1;
    if (speedRatio1 >= 1){
      currMotorSpeed1 = maxMotorSpeedFw1;
    else{
      currMotorSpeed1 = speedRatio1 * maxMotorSpeedFw1;
    if (tiltX > 0 && tiltX < maxTilt) {
      currMotorSpeed1 += tiltX;
    else if (tiltX > 0 && abs(tiltX) >= maxTilt) {
      currMotorSpeed1 += maxTilt;
    if (abs(tiltY) < maxTilt) {
      currMotorSpeed1 += tiltY;
    else if (tiltY > 0 && abs(tiltY) >= maxTilt) {
    if (motor1State == IDLE){
      handleMotor1(RE_1_counter);
  else if (RE_1_counter <= -trigger){
    angVelf1 = getAngVel(abs(avgAngAccel1), abs(angle1));
      currMotorSpeed1 = maxMotorSpeedRv1;
    else{
    currMotorSpeed1 = speedRatio1 * maxMotorSpeedRv1;
  else if (RE_2_counter <= abs(trigger)){
    currDir2 = 'Idle';
    resetCounter2();
  if (RE_2_counter >= trigger)
    currUserSpeed1 = getLinVel(angVelf2, mainWheelRadiusM);
    speedRatio2 = currUserSpeed2 / maxUserSpeed2;
    if (speedRatio2 >= 1){
      currMotorSpeed2 = maxMotorSpeedFw2;
    else{
      currMotorSpeed2 = speedRatio2 * maxMotorSpeedFw2;
    if (tiltX > 0 < maxTilt) {
      currMotorSpeed2 += tiltX;
    else if (tiltX < 0 && abs(tiltX) >= maxTilt) {
      currMotorSpeed2 += maxTilt;
      currMotorSpeed2 += tiltY;
    if (motor2State == IDLE){
      handleMotor2(RE_2_counter);
  else if (RE_2_counter <= -trigger){
    angVelf2 = getAngVel(abs(avgAngAccel2), abs(angle2));
    currUserSpeed2 = getLinVel(angVelf2, mainWheelRadiusM);
      currMotorSpeed2 = maxMotorSpeedRv2;
    else{
    currMotorSpeed2 = speedRatio2 * maxMotorSpeedRv2;
	delay(1);
  resetCounter1();
  delay(1);
  resetCounter2();
void handleMotor1(int RE_1_counter){
  int buttonState = digitalRead(ForwardOrReverseButton); //reads status of the forward or reverse switch
  if (mode == "Turn")
    if (RE_1_counter - RE_2_counter > 0){
      startMotor1Forward(); //right motor forward
    else if (RE_1_counter - RE_2_counter < 0){
      startMotor1Reverse(); //right motor back
    return;
  switch (RE_1_counter)
    case -trigger: //trigger value on rotary encoder
      if (buttonState == LOW) //reverse is active
    case trigger:
      if (buttonState == HIGH) //forward is active
    default:
void handleMotor2(int RE_2_counter){
  if (mode == "Turn")
      startMotor2Reverse(); //right motor forward
      startMotor2Forward(); // left turn
    return;
  switch (RE_2_counter)
    case -trigger:
    case trigger:
      default:
void startMotor1Forward()
  motor1State = MOTOR1_FORWARD;
  digitalWrite(Motor1Direction, LOW);
  analogWrite(Motor1Speed, currMotorSpeed1);
  startTime1 = millis();
  resetCountersAndDelay1();
void startMotor1Reverse()
  motor1State = MOTOR1_REVERSE;
  digitalWrite(Motor1Direction, HIGH);
void startMotor2Forward()
  motor2State = MOTOR2_FORWARD;
  digitalWrite(Motor2Direction, HIGH);
  analogWrite(Motor2Speed, currMotorSpeed2);
  startTime2 = millis();
  resetCountersAndDelay2();
void startMotor2Reverse()
  motor2State = MOTOR2_REVERSE;
  digitalWrite(Motor2Direction, LOW);
void resetCountersAndDelay1() {
  RE_1_counter = 0; // Reset Motor 1 counter
  //RE_2_counter = 0; // Reset Motor 2 counter
  delay(PauseBeforeCountingOnEncodersResumes); // Delay for 2 seconds
  // After resetting counters and the delay, return to the loop
  return;
void resetCountersAndDelay2() {
  //RE_1_counter = 0; // Reset Motor 1 counter
  return;
void setup(){
  // Setup Serial Monitor
  Wire.begin();
  pinMode(RE_1_outputDT, INPUT);
  pinMode(RE_2_outputDT, INPUT);
  pinMode(Motor1Speed, OUTPUT);
  pinMode(Motor2Speed, OUTPUT);
  pinMode(Motor1Direction, OUTPUT);
  pinMode(Motor2Direction, OUTPUT);
  pinMode(ForwardOrReverseButton, INPUT_PULLUP);
  pinMode(calibButton, INPUT_PULLUP);
  RE_1_LastState = digitalRead(RE_1_outputCLK);
  RE_2_LastState = digitalRead(RE_2_outputCLK);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C, false, false);
  display.display();
  display.clearDisplay();
  // Initialize mpu;
  if (!mpu.begin()) {
    Serial.println(F("Failed to find MPU6050 chip"));
    while (1) {
      delay(10);
  Serial.println(F("MPU6050 Found!"));
  //Set accelerometer range and filter bandwidth (optional, based on your requirements)
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
  mpu.setGyroStandby(true, true, true);
  mpu.setTemperatureStandby(true);
  calibration();
  //Timer1 setup
  Timer1.initialize(100); // 100 us => 10kHz
  Timer1.pwm(NPN_PIN,0); //Start with 0 duty
  // Changed from 19200 to 9600 which seems to be default for Arduino serial monitor
  readTime();
  mode = "Drive";
  robojaxText("Steering Mode Engaged!",4,3,1,true);
  if (motor1State != IDLE && currMillis - startTime1 >= motorDuration)
  {//initial state of motors is to remain idle until action
    motor1State = IDLE;
    digitalWrite(Motor1Speed, NoSpeed);
  if (motor2State != IDLE && currMillis - startTime2 >= motorDuration)
    motor2State = IDLE;
    digitalWrite(Motor2Speed, NoSpeed);
   int calibButtonState = digitalRead(calibButton);
  willMotorStart();
  if (calibButtonState == HIGH){
    calibration();
Could also be the wiring, poor choice of motor drivers, inadequate power supply, etc.
Post the required details.
Hint: get the motors running properly with the minimum code required to test them, before piling in any of the extras. Then add the extras, one at a time, testing as you go. When it quits working, fix the problem.
Wiring is fine. Like I said, it all works independently. When I added the calibration function it stopped working but the screen works, and the buttons work. The problem is likely in the willMotorStart() function and its only counting one encoder.
That is where you should look for the problem. This is elementary debugging technique.
Did you intend to decrement before iterating?
Are you sure that the second argument to atan2() is !=0 in all three expressions?
