Mounting sensor on protoboard
I’m trying to find the cleanest way to put this sensor on a protoboard / perfboard. Can I drill and then use pins on these pads on the bottom? Or should I just unsolder the sensor from the module. (AM2302 on a Seeed connector module) (Yes, that is the name) Let me know your opinions, I’m new to protoboards but learning a lot every day. :smile:
Thanks,
Leo
That would be a DH11 or DH22. You could desolder it, but you also got a resistor and a capacitor there. The resistor I'm pretty sure you need, the capacitor... maybe. Search for their values, and add at least the resistor.
At closer inspection, you don't need to desolder anything, but you need those holes free of solder, or heat up the solder and wiggle the pins in.
Hi @leod123 ,
as @ledsyn posted you had to add at least a 1k Pullup resistor according to Adafruit's datasheet
Source: https://cdn-shop.adafruit.com/datasheets/Digital+humidity+and+temperature+sensor+AM2302.pdf
Regarding the capacitor they say
One capacitor valued 100nF can be added between VDD and GND for
wave filtering.
I'd would recommend taking a look at jst-xh crimping tools ... It makes it easier to replace a defect sensor board.
There are crimping tool sets available at reasonable prices that can also be used for customized breadboard jumper wires ...
Good luck and enjoy Arduino!
ec2021
Is the pin spacing on the sensor board known?
I would put a thin sheet of plastic ( plasticard) under the board and secure to your prototyping board by looping wires through the screw holes and soldering to the prototype board .
If you then look on eBay you will find small prewired plugs that fit that socket , plug in and solder the ends to the prototype board .
I actually just got one of these for this project! Excited to get some nice clean ribbons going for my sensors
I think this will be my approach, it’s just so odd to me that they don’t go all the way thru. Hopefully they’re not too shallow I guess
I would but it’s not JST, it’s a Seeed or Grove connector so it’s undersize.
I guess the holes are soldered because the board has been wave soldered. Is the connector blocking btw, and you need to desolder it first?
Wait a minute, it's not through holes?
