I am trying to build a project, where short MP3-files (alarms, signals) are triggered by pressing the button on a remote control.
The signal of a 433 MHz remote would be recieved by a RXB6 wireless receiver module. A DFPlayer Mini would then play the MP3-file and send the signal to 2 RCA jacks.
Could you please take a look if I have done everything correctly, or if anything needs to be changed?
Due to this source DFPlayer consumption the player requires maximum 200 mA when playing sound. That would be less than the 500 mA that is the recommended maximum for external devices driven by the 5V pin of the Arduino UNO (to avoid overheating the onboard voltage regulator).
So you could connect the UNO to a power supply with 7VDC to 12VDC (1 Amp) and use the regulated 5V output for the other components.
No, the Arduino barel jack needs 7 to 12 VDC ... the reason is that it drives the onboard voltage regulator that requires at least 7VDC to generate the regulated 5VDC. If you connect the appropriate power source to the UNO's barrel jack the onboard regulator will be able to supply enough power to the UNO, the DFPlayer and the RF Receiver.
I guess you haven't read the link I posted regarding the "power-pins", did you? It's worth reading unless you don't mind risking your hardware in worst case ...
I use a "phone charger cube" (of the many found in the wild... which are usually 1A) for small projects and cut a USB cable to expose the power leads (even the cables found on every street still work... but verify), and splice (solder, heat-shrink) other cables to the length I need to reach a wall socket for mains power. Audio might get noisy. Also... don't expect boomin-dolby-HiFi-surround-sound... unless you experiment with a good amplifier.
It constraints the current on the Arduino TX line thus reducing electromagnetic interference (EMI). Looks as if the Serial TX line can affect the players electronics (poor shielding?!?). In addition you could try to physically separate or shield the serial lines to prevent EMI.
I highly recommend to build the system using a breadboard to verify hardware configuration and software. You can easily test whether capacitors might improve the use or not.
