Hello, I am having trouble calibrating the mpu-6050 sensor. The code I use to calibrate does not give me my offset results. I connected the MPU6050 sensor to sca = a5 sda = a4 gnd and 5 v pins, I connected it to pin = 2 and I attach the screenshot below.
Some of the forms I researched told me not to try without making an int connection, but the result still did not change. Can you help me?
Please post the code that you are using
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code
