Yea, I know its one of these again, but I've allready googled as much as I can and I still haven't fixed it.
These (3) are the (probably shitty) mpu's I bought (first pic on site is not the actual module for some reason):
Copied the wiring from this video (except on an uno):
Tried the Jeff library, hangs after "Initializing I2C devices...", once I pull out "A4" and "A5" pin it continues with a conection failed (obviously).
Tried the I2C_Scanner, hangs on "Scanning...", same thing with pulling the pins out.
Tried several other tutorial test code, same lack of response.
(This happens on all 3 modules)
So I've either:
- Fried my mpu's by putting it on 5v, which I still don't know is possible or not, because people seem to be conflicted whether it has an onboard regulator or not.
- Got shipped 3 non-working mpu's.
- Messed up soldering all 3 mpu's.
- Something else I'm missing.
If I need to answer any questions I'll be back in around 12-14 hours, cus it's late and I've allready spent way too long trying to troubleshoot.
Recommendations on which mpu's to buy, if these aren't fixable, are also appreciated.
Thanks in advance for any help.
