MPU9250 IMU, how to get the X angle out of it?
This might be super silly simple, but I just want to get the current angle out of the IMU.
I am using the basic example,
#include "MPU9250.h"
#include <Wire.h>
// an MPU9250 object with the MPU-9250 sensor on I2C bus 0 with address 0x68
MPU9250 IMU(Wire,0x68);
int status;
  // serial to display data
  while(!Serial) {}
  // start communication with IMU
  status = IMU.begin();
  if (status < 0) {
    Serial.println("IMU initialization unsuccessful");
    Serial.println("Check IMU wiring or try cycling power");
    Serial.print("Status: ");
    Serial.println(status);
    while(1) {}
  // read the sensor
  IMU.readSensor();
  // display the data
 // Serial.print(IMU.getAccelX_mss(),6);
 // Serial.print("\t");
 // Serial.print(IMU.getAccelY_mss(),6);
 // Serial.print(IMU.getAccelZ_mss(),6);
  Serial.print(IMU.getGyroX_rads(),6);
  Serial.print("\t");
  Serial.print(IMU.getGyroY_rads(),6);
  Serial.print("\t");
  Serial.print(IMU.getGyroZ_rads(),6);
  Serial.print("\t");
  Serial.print(IMU.getMagX_uT(),6);
  Serial.print("\t");
  Serial.print(IMU.getMagY_uT(),6);
  Serial.print("\t");
  Serial.print(IMU.getMagZ_uT(),6);
  Serial.print("\t");
  Serial.println(IMU.getTemperature_C(),6);
  delay(100);
I thought the getGyroX_rads() would get me the angle, but not. It gives me the rate of change.
As the IMU is static at 45 degrees inclination, this goes back to zero.
I thought that's what IMU.getAccelX_mss, is for, !?!?!
Anyways, this is so fancy, can I please just get the incline angle?
Thanks
https://wiki.dfrobot.com/How_to_Use_a_Three-Axis_Accelerometer_for_Tilt_Sensing
