I already pre- heated the MQ-2 all the components in my circuit is functional. The code seems to work but the sensor is not detecting lpg gas or smoke. I even changed the sensor used a new one. Currently the arduino is directly connected to my laptop for power supply.
int red_led=3;//indicates gas
int green_led=2;//indicates normal
int smokeA0 = A0;//indicates sensor is connected to A5
int buzzer=4;
int sensorThres=400;//The threshold value
pinMode(red_led,OUTPUT);//red led as output
pinMode(green_led,OUTPUT);//green led as output
pinMode(buzzer,OUTPUT);
pinMode(A0,INPUT);//sensor as input
Serial.begin(9600);//starts the code
int gas_avalue=analogRead(smokeA0);//reads sensor value
if (gas_avalue > sensorThres) {//sees if it reached threshold value
digitalWrite(red_led, HIGH);//turns on red led
digitalWrite(green_led, LOW);//turns off green led
digitalWrite(buzzer, HIGH);//turn buzzer on
else//if it hasn't reached threshold value
digitalWrite(red_led, LOW);//turns red led off
digitalWrite(green_led, HIGH);//turn green led on
digitalWrite(buzzer, LOW);//turn buzzer off
delay(100);//delay 0.1 sec
Please post the loop() function showing how you tried to print it. Have you checked that the baud rate of the Serial monitor matches that of the Serial.begin() ?
I am actually new to this so I didnt understand however I updated the code
int buzzer=4;
Serial.println("GAS LEAKING");
Serial.println("NORMAL");
In serial monitor it prints "Normal"
Is this what you are referring to?
No. What I had in mind was printing the value returned by the sensor before you test it. Like this
int gas_avalue = analogRead(smokeA0); //reads sensor value
Serial.print("sensor value : "); //print the sensor value
Serial.println(gas_avalue);
{ //sees if it reached threshold value
etc, etc
