MSGEQ7 problem [SOLVED]
Hello,
I have recently tried to create an Audio Visualizer with MSGEQ7. First i tried to understand how the chip works in order to put it in my project. I connected the chip as they say in datasheet [first attachment] , but the readings are always the same and equal to 800 +- 10. I tried other connections from projects in this site, however the results are always the same. I checked the connections and the audio output they seemed to work as they should. Can anyone help me with this, because i don't have any idea what is wrong with it.
The code
Test Sketch for the MSGEQ7
from Mixed Signal Integration
the IOs in this Sketch are
compatible with the Shield
from Sparkfun:
Author: Simon Waldherr
License: MIT
int AnalogIn = 0; // read from multiplexer using analog input 0
int NextBand = 2; // strobe (next band) is attached to digital pin 4
int ResetPin = 3; // reset is attached to digital pin 5
int Spectrum[7]; // array to store analog values
int filter = 80; // *** added min level above noise
// init IO
// delay(250); // *** not necessary
// pinMode(AnalogIn, INPUT); // *** not necessary
pinMode(NextBand, OUTPUT);
pinMode(ResetPin, OUTPUT);
analogReference(DEFAULT);
digitalWrite(ResetPin, HIGH);
digitalWrite(ResetPin, LOW); // *** added
// digitalWrite(NextBand, HIGH); //*** removed
// init Serial
Serial.begin(9600); //*** chg'd from 115200 to 9600
//*** make sure Monitor is 9600
Serial.println("|______________________________|");
Serial.println("| MSGEQ7 |");
Serial.println("|------------------------------|");
Serial.println("| Seven Band Graphic Equalizer |");
Serial.println("| on an Arduino Shield |");
Serial.println("| with Serial output |");
// wait
delay(5000);
// *** Reset here works but slighly better response without it
// digitalWrite(ResetPin, HIGH); // reset band to 63 Hz
// digitalWrite(ResetPin, LOW);
for (int i = 0; i < 7; i++) // for loop to save values to array
// HIGH to LOW transition works best here
digitalWrite(NextBand, HIGH); //*** added
digitalWrite(NextBand, LOW);
delayMicroseconds(22); // to allow the output to settle
// Spectrum = doMath(analogRead(AnalogIn)); // read actual value to array
  • // read spectrum level and filter noise*
    Spectrum = constrain(analogRead(AnalogIn), filter, 1023); //*** added
    // digitalWrite(NextBand, HIGH); //*** moved up // select next band (160Hz, 400Hz, 1000Hz, 2500Hz, 6250Hz, 16kHz)
    _ delayMicroseconds(3); //*** probably not necessary_
    * for (int i = 0; i < 7; i++) // for loop to print array to Serial*
    if (Spectrum == filter ) //*** chg'd // ignore values lower than 100 (you also can use doMath())
    * Serial.print("\t");*
    * Serial.print("0");*
    * else*
    _ Serial.print(Spectrum*);
    Serial.println(); // Serial new line*
    * //delay(500); // this sketch prints really much data, you can slow down if you have to.
    }[/td]
    [/tr]
    [/table]
    1.png_
Spectrum is an array. So trying to print it or apply a constrain to it is never going to work. That code doesn't even compile so I don't believe it prints any values at all.
OTOH your main problem may be that you have a fake MSGEQ7 because there seem to be a lot of them about. Where did you get yours from?
Steve'
I bought them on Ebay from Chinese supplier so they are probably fakes you say. Thank you for the information.
