Here's the code I'm using. I pulled it from a different tutorial, but I don't see why it wouldn't work with the pins adjusted a little..
Test Sketch for the MSGEQ7
from Mixed Signal Integration
the IOs in this Sketch are
compatible with the Shield
from Sparkfun:
http://www.sparkfun.com/products/10306
Author: Simon Waldherr
License: MIT
int AnalogIn = 0; // read from multiplexer using analog input 0
int NextBand = 4; // strobe (next band) is attached to digital pin 4
int ResetPin = 5; // reset is attached to digital pin 5
int Spectrum[7]; // array to store analog values
// init IO
delay(250);
pinMode(AnalogIn, INPUT);
pinMode(NextBand, OUTPUT);
pinMode(ResetPin, OUTPUT);
analogReference(DEFAULT);
digitalWrite(ResetPin, LOW);
digitalWrite(NextBand, HIGH);
// init Serial
delay(250);
Serial.println("|______________________________|");
Serial.println("| MSGEQ7 |");
Serial.println("|------------------------------|");
Serial.println("| Seven Band Graphic Equalizer |");
Serial.println("| on an Arduino Shield |");
Serial.println("| with Serial output |");
// wait
delay(5000);
digitalWrite(ResetPin, HIGH); // reset band to 63 Hz
for (int i = 0; i < 7; i++) // for loop to save values to array
digitalWrite(NextBand, LOW);
delayMicroseconds(22); // to allow the output to settle
Spectrum[i] = doMath(analogRead(AnalogIn)); // read actual value to array
digitalWrite(NextBand, HIGH); // select next band (160Hz, 400Hz, 1000Hz, 2500Hz, 6250Hz, 16kHz)
delayMicroseconds(3);
for (int i = 0; i < 7; i++) // for loop to print array to Serial
if (Spectrum[i] < 10 ) // ignore values lower than 100 (you also can use doMath())
Serial.print("\t");
Serial.print("0");
Serial.print("\t");
Serial.print(Spectrum[i]);
Serial.println(); // Serial new line
//delay(500); // this sketch prints really much data, you can slow down if you have to.
int doMath(int analogvalue) // you can filter the analog data and do your own math
int result;
result = (analogvalue-32)/10;
return result;
The problem is that when I look at the Serial Monitor output, it shows a bunch of zeros... If I take the Analog pin from the chip out of A0, the monitor prints out a bunch of rows counting down from 41.. I'm guessing that doesn't really mater since it's not even reading the input from the chip..
Anyways anyone have any idea what could be causing this? I've been double-checking my circuit and the code for hours and can't figure it out...
I made some changes to your code and it now works good on my spectrum analyzer. The new code has comments for each change. Let me know if you have any questions as to why the change. I try to keep each program as simple as possible, so I marked some things as "not necessary". These changes don't make or break the program they just make it smaller.
As for the reading the EQ7 analog output and applying a noise filter, there are different ways to do it. I put the one that gives the best results in your code. Trust me, I've tried all sorts of math filters and "map" with various scales, and "constrain" seems to work the best.
Regards,
Dennis
from Sparkfun:
License: MIT
int filter = 80; // *** added min level above noise
// init IO
// delay(250); // *** not necessary
// pinMode(AnalogIn, INPUT); // *** not necessary
digitalWrite(ResetPin, LOW); // *** added
// digitalWrite(NextBand, HIGH); //*** removed
// init Serial
Serial.begin(9600); //*** chg'd from 115200 to 9600
//*** make sure Monitor is 9600
// wait
delay(5000);
// *** Reset here works but slighly better response without it
// digitalWrite(ResetPin, HIGH); // reset band to 63 Hz
// digitalWrite(ResetPin, LOW);
// HIGH to LOW transition works best here
digitalWrite(NextBand, HIGH); //*** added
// Spectrum[i] = doMath(analogRead(AnalogIn)); // read actual value to array
// read spectrum level and filter noise
Spectrum[i] = constrain(analogRead(AnalogIn), filter, 1023); //*** added
// digitalWrite(NextBand, HIGH); //*** moved up // select next band (160Hz, 400Hz, 1000Hz, 2500Hz, 6250Hz, 16kHz)
delayMicroseconds(3); //*** probably not necessary
if (Spectrum[i] == filter ) //*** chg'd // ignore values lower than 100 (you also can use doMath())
Serial.print("\t");
Serial.print("0");
Serial.print("\t");
/* *** remove
int result;
return result;
Awesome! Thanks Dennis. I'll give that new code a shot. Before I do that, though, I have one more question.. I've been running it using the 5V pin of the Arduino (which is being powered by my laptop). Is that safe? Most people I've seen are powering both separately using a 5V 2A source for the chip. All I have at the house is a 5V 4A (and I'll shoot myself if I have to drive up to RadioShack again)..
Here's the output when I have a separate power source.. I have the DC jack's power going to my breadboard, ground going to the Arduino, and then the breadboard ground to the Arduino.
For power, I always use an external supply. Do your LEDs require ubber amps? I don't trust the usb 5V and even unplug it after a download for serious testing.
I would check your audio in connection since I ran the same sketch on my MSGEQ7 and got different results.
Hm... Ok, well, I swapped out for a different 3.5mm jack and the output still doesn't seem quite right. The output stays pretty much consistent across all the different columns. It's either the same number all the way across, or it'll be +-1.. Maybe the micro controller is fried? As far as I can tell they should all be different to represent the different spectrums..
So far I don't have it hooked up to any LEDs . I was just wanting to make sure it was working correctly before integrating it into my light setup.
Another interesting symptom.. If I watch the serial monitor run for around 2 minutes, the output slowly rises up to over 1000. After around 5 minutes it just prints out 1023 for all the lines..
I don't know what to tell you as the schematic you posted is correct for the MSGEQ7. And the program works on my analyzer. That only leaves the processor and your (I assume breadboard) circuit. The odds are that the problem is the EQ7 circuit so drag out a multimeter and check each connection.
Measure 5V on EQ7 pin 1, C4, R1.
Power off and measure resistance (continuity) between all other connections.
I doubt if its the processor but you can use different analog and digital pins if you want to eliminate the possibility of a bad I/O port.
The only other suggestion I have is ... while testing, use a Function Generator program on your pc. The audio frequency and level will be constant and predictable. Music varies too much for troubleshooting. The program I use is FG Lite (Marchand Function Generator) and its free.
Tested and I'm getting about 5.15v on all of those. I checked the other circuits and all of them showed some resistance (I think? Not really sure what to look for).. But anyways, I think the issue might be with the 33pF capacitor (or what I thought was a 33pF). I did some research and it looks like it may actually be a 330000pF capacitor (says 334 on it). So I can see how that would be an issue. I ordered a new 33pF one and we'll see what happens.
