MU6050
Bonjour,
j'ai comme projet bac de créer un longboard connecté. Nous utilisons un capteur MPU6050 pour avoir l'accélération et l'inclinaison.
Nous avons le programme suivant:
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = "); Serial.print(AcX);
Serial.print(" | AcY = "); Serial.print(AcY);
Serial.print(" | AcZ = "); Serial.print(AcZ);
Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
Serial.print(" | GyX = "); Serial.print(GyX);
Serial.print(" | GyY = "); Serial.print(GyY);
Serial.print(" | GyZ = "); Serial.println(GyZ);
delay(2000);
Et nous récupérons les valeurs suivantes (sans déplacer le MPU):
AcX = 740 | AcY = 44 | AcZ = 17928 | Tmp = 25.42 | GyX = -388 | GyY = -147 | GyZ = 122
AcX = 632 | AcY = 32 | AcZ = 17788 | Tmp = 25.38 | GyX = -410 | GyY = -141 | GyZ = 180
AcX = 576 | AcY = 164 | AcZ = 17916 | Tmp = 25.33 | GyX = -392 | GyY = -163 | GyZ = 161
AcX = 612 | AcY = 84 | AcZ = 17796 | Tmp = 25.28 | GyX = -389 | GyY = -167 | GyZ = 174
AcX = 792 | AcY = 76 | AcZ = 17796 | Tmp = 25.24 | GyX = -387 | GyY = -167 | GyZ = 187
AcX = 564 | AcY = -16 | AcZ = 17624 | Tmp = 25.24 | GyX = -413 | GyY = -162 | GyZ = 171
AcX = 696 | AcY = 4 | AcZ = 17764 | Tmp = 25.28 | GyX = -372 | GyY = -170 | GyZ = 177
AcX = 700 | AcY = -28 | AcZ = 17732 | Tmp = 25.19 | GyX = -405 | GyY = -177 | GyZ = 137
AcX = 680 | AcY = 64 | AcZ = 17824 | Tmp = 25.09 | GyX = -382 | GyY = -183 | GyZ = 148
Déjà les valeurs me sembles bizarre, j'ai calculé la somme de la normes des valeurs sur X, Y, Z et j'ai une accélération totale autours des 17000 ou 18000. D'après l'unité de la doc, les unités de l'accélération du capteur est le mg (milligal). Je trouve donc en convertissant une valeur d'environ 0,17677 m/s². Je ne comprend pas pourquoi sa m'affiche cette valeur, je suis pas sensé trouver 9.81m/s² (accélération de la terre).
Si quelqu'un sait ou est le problème, sa fait des heures qu'on planche dessus mais on voit pas où il y a un problème.
Merci de votre aide
