Hi!
I am trying to make two RFID readers using Sparkfun ID-3 LA module, I have managed to get the attached code to work for one reader, but when I try to connect another one, none of them work (or it has a extremely low range, 1 cm or less). But if I disconnect one of the two antennas while the code is executing, suddently the other reader starts working.
I have made two antennas and the idea is to have both of them reading some passive tags at the same time (or at least to be available to read tags at the same time), but it looks like there is some trouble with the Serial port, so if someone could help me I would be really grateful.
I am using the Arduino Mega wiring the readers like follows:
ID-3 LA - Arduino
Vcc - +5V
READ - None
D0 - RX1/RX2
D1 - None
FORM - GND
TIR - None
GND - GND
RES - +5V
ANT - One side of the handmade antenna
ANT - The other side of the handmade antenna
CP - None
The code is:
// RFID reader ID-3 La for Arduino
// Based on code by BARRAGAN <https://people.interaction-ivrea.it/h.barragan>
// and code from HC Gilje - https://hcgilje.wordpress.com/resources/rfid_id12_tagreader/
// Modified for Arduino by djmatic
// Modified for ID-12 and checksum by Martijn The - https://www.martijnthe.nl/
// Use the drawings from HC Gilje to wire up the ID-12.
// Remark: disconnect the rx serial wire to the ID-12 when uploading the sketch
Serial1.begin(9600);
Serial2.begin(9600);
Serial.begin(9600);// connect to the serial port
//Serial1.begin(9600);
Serial.println("Ready");
void loop () {
byte i = 0;
byte val = 0;
byte code[6];
byte checksum = 0;
byte bytesread = 0;
byte tempbyte = 0;
if((val = Serial1.read()) == 2) { // check for header
bytesread = 0;
while (bytesread < 12) { // read 10 digit code + 2 digit checksum
if(Serial1.available() > 0) {
val = Serial1.read();
if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
// Do Ascii/Hex conversion:
if ((val >= '0') && (val <= '9')) {
val = val - '0';
} else if ((val >= 'A') && (val <= 'F')) {
val = 10 + val - 'A';
// Every two hex-digits, add byte to code:
if (bytesread & 1 == 1) {
// make some space for this hex-digit by
// shifting the previous hex-digit with 4 bits to the left:
code[bytesread >> 1] = (val | (tempbyte << 4));
if (bytesread >> 1 != 5) { // If we're at the checksum byte,
checksum ^= code[bytesread >> 1]; // Calculate the checksum... (XOR)
tempbyte = val; // Store the first hex digit first...
bytesread++; // ready to read next digit
// Output to Serial:
if (bytesread == 12) { // if 12 digit read is complete
Serial.print("5-byte code: ");
for (i=0; i<5; i++) {
if (code[i] < 16) Serial.print("0");
Serial.print(code[i], HEX);
Serial.print(" ");
Serial.print("Checksum: ");
Serial.print(code[5], HEX);
Serial.println(code[5] == checksum ? " -- passed." : " -- error.");
bytesread = 0;
if((val = Serial2.read()) == 2) { // check for header
bytesread = 0;
if(Serial2.available() > 0) {
val = Serial2.read();
val = val - '0';
Serial.print(" ");
bytesread = 0;
