Multiple servo with multiple sensors
I haven't tried with servos yet, but i am aware of a voltage drop issue while connecting multiple servos. any suggestions will he appreciated highly...
The problem is not voltage drop. If you are powering the servos from the Arduino then it is very easy to damage the board as it can only supply a limited amount of current
You need to supply 5V to the servos from an external source either batteries or another source
thanks for the advise, i'll get back soon, just when i start working with those.
many thanks for your support.
If you use a single (9g) micro servo with no load on it then you can test the sketch using 5V from the Arduino
