I ordered a 1.3-inch OLED display, and it came today.
I plugged it into my Arduino Uno installed all the libraries and it started to glitch out it looked like this:
Thoughts and prayers.
Perhaps if, as well as installing the libraries, you also wrote some code as well it might work better?
What happens with a basic "hello world" sketch that is much less than 11kB long?
I didn't try that, and I don't know how
Uncompiled, untested
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1// Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
testdrawstyles(); // Draw 'stylized' characters
// Invert and restore display, pausing in-between
display.invertDisplay(true);
display.invertDisplay(false);
void testdrawstyles(void)
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0,0); // Start at top-left corner
display.println(F("Hello, world!"));
display.display();
display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw 'inverse' text
display.println(3.141592);
display.setTextSize(2); // Draw 2X-scale text
display.print(F("0x")); display.println(0xDEADBEEF, HEX);
delay(2000);
Now it printed out a huge line at the top.
And then it goes back to the original state
And I don't know if it matters but its a 1.3-inch display
Here is a link for it:
https://www.hestore.hu/prod_10035540.html
From your supplier web site it looks like a SD1106 and not SD1306 .
