Nano 328p vs 328PB
Hello
I have a number of NANO boards which, as it turns out, have the 328PB soldered on them.
The -PB versions have extra functionality over the standard -P version.
2 functions come through the procesor pins 3 and 6: SDA1 and SCL1, for an extra I2C bus.
In the -P version these pins were: 3=GND and 6=VCC
I noticed that on the boards with the -PB processor these pins are
still connected to the power lines GND and VCC
Apart from the fact that these processor pins are not externally
connected to 2 additional pins and therefore useless, they might even get damaged. I think...
Can somebody confirm this ?
Regards,
Rob
You are right. The PB is NOT a drop in replacement for thr the P.
If you should declare those pins as outputs you could indeed damage the part
But if you don't, it should be OK. The pins are on PORTE, which doesn't exist on the normal P version, so you'd have to go to some effort to make them outputs.
Yes the pins default to inputs so it should be OK.
It is a bad hardware design.
What is the marking on the PB chip exactly?
The exact marking on the chip is:
Atmel
MEGA328PB
-U
1743D TW
A4BUJD
Do you have a good reason to believe that the chip is genuine?
Likely it is not a 'design' at all, but a (cheaper, more available) ATmega328PB chip dropped onto a PCB that was created for an ATmega328P.)
I have no reason to believe that the chip is genuine or not.
Years ago I bought a few nano's for some experiments
Some boards had the 328P and some boards had the 328PB on it.
So I think that what westfw writes could be true: cheaper and more available.
Looks like you aren't the first.
https://forum.arduino.cc/t/warning-nano-clones-with-mega328pb-u-chips/520381
I can't find anything that suggests 328PB-U is an Atmel marking. I think their's would be 328PB-AU.
