Nano 33 IOT, Multiple DS18B20 Sensors, Micro SD Card Module
I have the Nano 33 IOT, Multiple DS18B20 temp sensors (addresses recorded), and a Micro SD card module. Everything is wired correctly, I know from testing.
I can read and display the sensor data from the DS18B20's onto the serial monitor no problem. I can even use the example code to read / write and verify the data onto the Micro SD card. My only issue is writing the temp data to the card. I'd love to use the internal RTC to include a time stamp on each data entry. I would like to read the temp sensors once per minute. The file should probably be a CSV to use Excel spreadsheets or something similar.
I have looked all over on how to put the data onto the SD card but I'm not seeing anything that works like I have setup. I want to use the temp sensors address in the code.
At some point I would love to include sensor readings from the onboard 6DOF sensor and an added GPS sensor at some point. I really just want to focus on the temp sensors writing onto the SD card.
How do I tell it how to separate the columns and whatnot?
Please let me know if you need any additional info on this project. I really appreciate any and all help I may get.
CSV means
Comma seperated variable
So seperate your variables with commas.
There is a data logging example included with the SD library.
I should have known on the CSV thing.
I've been trying to modify the datalogging example to work with my needs. with no luck.
Your code is a state secret then, is it?
The code I'm currently working on is pasted below. It's what I got done so far in the little free time I have had. I took the datalogger example and started adding the multi temp sensor code i tested to work. I'm not sure where to go next.
#include <SPI.h>
#include <SD.h>
#include <OneWire.h>
#include <DallasTemperature.h>
const int chipSelect = 10;
// Data wire is plugged into port 4 on the Arduino
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Addresses of 3 DS18B20s
uint8_t InsideBoxTemp[8] = { 0x28, 0x11, 0x60, 0xf3, 0x58, 0x20, 0x01, 0x5b };
uint8_t OutsideBoxTemp[8] = { 0x28, 0x3e, 0x8c, 0x78, 0x58, 0x20, 0x01, 0x7f };
  sensors.begin();
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1);
  Serial.println("card initialized.");
  // make a string for assembling the data to log:
  String dataString = "";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) {
      dataString += ",";
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  File dataFile = SD.open("Temp01.txt", FILE_WRITE);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening Temp01.txt");
I think your temperature code is rubbish, so go to one that works.
"Arduino 1-Wire Tutorial" Arduino 1-Wire Tutorial
Opening and closing the file in the loop is a bad idea, but not immediately fatal. Open once in setup.
My temperature code works perfectly fine, thanks!
Ok...
