Temperature data log with Arduino with DS18B20 + DS1302 + SPI ICSP
Hi guys, I am currently doing a project to create a cooling fan for a room. For the temperature and time reading I am using DS18B20 temperature sensor and a DS1302 RTC. I am using a SPI ICSP micro SD card adapter module to record the temperature reading and time.
Currently I am stuck at the code, I manage to create the code that will show the temperature and time on serial monitor but I am having trouble to code the Arduino to save the data in the SDCard.
Can someone help to solve the problem? Bellow is my sketch code
//Start of RTC
#include <virtuabotixRTC.h>
// Creation of the Real Time Clock Object
virtuabotixRTC myRTC(6, 7, 8);
//End of RTC
//Stat of temperature
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into digital pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
int deviceCount = 0;
float tempC;
//end of temperature
void setup()  {
  // Set the current date, and time in the following format:
  // seconds, minutes, hours, day of the week, day of the month, month, year
  myRTC.setDS1302Time(0, 7, 12, 3, 31, 5, 2023);
//Start of temperature setup
  sensors.begin();	// Start up the library
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  deviceCount = sensors.getDeviceCount();
  Serial.print(deviceCount, DEC);
  Serial.println(" devices.");
  Serial.println("");
//End of temperature setup
void loop()  {
  //Start of RTC loop
  // This allows for the update of variables for time or accessing the individual elements.
  myRTC.updateTime();
  // Start printing elements as individuals
  Serial.print("Current Date / Time: ");
  Serial.print(myRTC.dayofmonth);
  Serial.print("/");
  Serial.print(myRTC.month);
  Serial.print("/");
  Serial.print(myRTC.year);
  Serial.print("  ");
  Serial.print(myRTC.hours);
  Serial.print(":");
  Serial.print(myRTC.minutes);
  Serial.print(":");
  Serial.println(myRTC.seconds);
  // Delay so the program doesn't print non-stop
  //End of RTC loop
  //start of temperature loop
  // Send command to all the sensors for temperature conversion
  sensors.requestTemperatures();
  // Display temperature from each sensor
  for (int i = 0;  i < deviceCount;  i++)
    Serial.print("Sensor ");
    Serial.print(i+1);
    Serial.print(" : ");
    tempC = sensors.getTempCByIndex(i);
    Serial.print(tempC);
    Serial.print((char)176);//shows degrees character
    Serial.print("C  |  ");
    Serial.print(DallasTemperature::toFahrenheit(tempC));
    Serial.println("F");
  //end of temperature loop
  Serial.println("");
For every device I 1st write (or modify the example) a sketch to prove I can get it to work.
Here is mine for the SD card.
The code:
Opens / begins the SD card
looks for a file starting with 100.csv and if exist continues until a file does not exist then opens it.
It writes the full time and date.
  SD card read/write
  Mod 01 make file name a string and iterate until we find a unused file name.
  Mod 02 add capability to increment filename.
  Rev 03 tested successfully on Arduino M0
  SD card attached to SPI bus on ICSP Header.
  SD Board power = 5V (for large board with EEPROM)
  based on code created: Nov 2010 by David A. Mellis, 9 Apr 2012 by Tom Igoe
  This code is in the public domain.
driver has a 512 byte buffer then write to SD
Closing the file forces any buffered data to be written to the SD and also updates
the file's directory entry.
If you don't close the file, you will lose all data written the file since it was opened,
not just the last buffer, since the directory entry will not be updated.
#include <SPI.h>
#include <SD.h>
// *** SD Card declarations **************************************************
#define SDCARD_CS_PIN 4
uint8_t fileNumb = 100;
char dataFile[8];
bool SD_Error = false;
File myFile;			// create instance of a "File" class
  SerialUSB.begin(115200);
  delay (2000);
// Initializing SD card....
  if (!SD.begin(SDCARD_CS_PIN))
    {SerialUSB.print("initialization failed");
     SD_Error = true;
// loop until we find a file that doesn't already exist.......
  do
     itoa(fileNumb, dataFile, 10);  // (value, Array, base)
     const char *extension = ".csv";
     strcat(dataFile, extension);  // syntax  strcat(dest, source)
     ++fileNumb;
    } while (SD.exists(dataFile));
SerialUSB.print("READY TO OPEN FILE FOR WRITING   = ");
SerialUSB.println(dataFile);
  myFile = SD.open(dataFile, FILE_WRITE);   // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
SerialUSB.println(myFile);
  // if the file opened okay, write to it:
  if (myFile) {
    myFile.println("data from boiler");     // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    SerialUSB.println("data from boiler");
    //SerialUSB.print(" data written to file:   ");
    myFile.close();                         // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  else {
    // if the file didn't open, print an error:
    SD_Error = true;
  SerialUSB.print("SD_Error = ");
  SerialUSB.print(SD_Error);
  // nothing happens after setup
I try out your code but is js print out an excel that write boiler temperature. Is there away to modified it so that it can record the temperature and time?
The datalogger and Dumpfile included in the SD examples are probably all you need. You already have the time data, so you just need to file.print it.
I see. I already got it to work tq very much for helping.
