Need 8 interrupts for Optical Encoders
Hello, I have four optical encoders that output two data channels, a quadrature signal and symmetry signal (both square waves). Ideally, I would like to use hardware interrupts for this, but no Arduinos can support this. Is there some sort of interface board I could use or some other method to achieve this? Let me know if you've guys got any ideas.
Thanks
The first question is - what are these optical encoders doing? That defines whether interrupts are a good idea or a silly idea. (It is always unwise to use interrupts for mechanical encoders.)
Your terminology regarding their outputs appears to be somewhat confabulated - perhaps you had better cite their datasheets.
The Arduino DUE got interrupts on every pin i think. If you want to use an Arduino UNO you'll have to use pin change interrupt (PCINT): Arduino Playground - PinChangeInt
I'll recommend to add som kind of hardware debounce. It makes it much easier for the Arduino:
for 4 optical (rotary) encoders (edit: 8 pins) you don't need 8 IRQ's!
You'll need just 1 timer IRQ (e.g., 100-200µs, but depending on rotation speed) , and then poll the related 16 pins one after the other and process them mathematically!
A Arduino Mega or Due will do it!
for 1 rotary encoder have a look at the following code (Arduino Mega), for 4 encoders do it 4x!
* Demo-Programm zur Auswertung eines händisch betriebenen
* Drehencoders (Quadraturencoder) mit dem Arduino per Timer-Interrupt
* Kann von jederman frei verwendet werden, aber bitte den
* Hinweis: "Entnommen aus http://www.meinDUINO.de" einfügen
// An die Pins 2 und 3 ist der Encoder angeschlossen
#define encoderA 2
#define encoderB 3
// Globale Variablen zur Auswertung in der
// Interrupt-Service-Routine (ISR)
volatile int8_t altAB = 0;
volatile int encoderWert = 0;
// Die beiden Schritt-Tabellen für volle oder 1/4-Auflösung
// 1/1 Auflösung
//int8_t schrittTab[16] = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0};
// 1/2 Auflösung ergibt bei Lego-Motoren 1 tick pro Grad (standard wie bei Lego)
int8_t schrittTab[16] = {0, 0,0,0,1,0,0,-1, 0,0,0,1,0,0,-1,0};
// 1/4 Auflösung
//int8_t schrittTab[16] = {0,0,0,0,0,0,0,-1,0,0,0,0,0,1,0,0};
* Interrupt Service Routine
* Wird aufgerufen, wenn der entsprechende Interrupt
* ausgelöst wird
ISR(TIMER1_COMPA_vect) {
  altAB <<= 2;
  altAB &= B00001100;
  altAB |= (digitalRead(encoderA) << 1) | digitalRead(encoderB);
  encoderWert += schrittTab[altAB];
* void setup()
* Wird einmal beim Programmstart ausgeführt
  pinMode(encoderA, INPUT);
  pinMode(encoderB, INPUT);
  noInterrupts(); // Jetzt keine Interrupts
  TIMSK1 |= (1<<OCIE1A);  // Timer 1 Output Compare A Match Interrupt Enable
  TCCR1A = 0; // "Normaler" Modus
  // WGM12: CTC-Modus einschalten (Clear Timer on Compare match)
  //        Stimmen OCR1A und Timer überein, wird der Interrupt
  //        ausgelöst
  // Bit CS12 und CS10 setzen = Vorteiler: 1024
  TCCR1B = (1<<WGM12) | (1<<CS12) | (1<<CS10);
  // Frequenz = 16000000 / 1024 / 15 = rd. 1kHz Abtastfrequenz;
  // Überlauf bei 14, weil die Zählung bei 0 beginnt
  OCR1A = 14;
  interrupts(); // Interrupts wieder erlauben
* void loop()
* Wird immer wieder durchlaufen
  while(true) {
    Serial.println(encoderWert);
    delay(100);
this is for the DUE for 6 encoder motors:
* Programm zur Auswertung eines manuell betriebenen
* Drehencoders (Quadraturencoder) mit dem Arduino Due
* per Due-Timer mit einer Abfragefrequenz von rd. 4-10kHz
* Entlehnt an http ://www.meinDUINO.de
#include <DueTimer.h>
char sbuf[100];
#define MAXMOTORS           6 // max number of encoder motors at Arduino Uno=2 // Due=6 // Mega=8
// motor 0
#define pinenc0A   22  // enc0A yellow
#define pinenc0B   23  // enc0B blue
#define pinmot0d1  24  // dir0-1   <<
#define pinmot0d2  25  // dir0-2
#define pinmot0pwm 10  // pwm enable0
// motor 1
#define pinenc1A   26  // enc1A yellow
#define pinenc1B   27  // enc1B blue
#define pinmot1d1  28  // dir1-1   <<
#define pinmot1d2  29  // dir1-2
#define pinmot1pwm  9  // pwm enable1
// motor 2
#define pinenc2A   30  // enc2A yellow
#define pinenc2B   31  // enc2B blue
#define pinmot2d1  32  // dir2-1   <<
#define pinmot2d2  33  // dir2-2
#define pinmot2pwm  8  // pwm enable2
// motor 3
#define pinenc3A   34  // enc3A yellow
#define pinenc3B   35  // enc3B blue
#define pinmot3d1  36  // dir3-1   <<
#define pinmot3d2  37  // dir3-2
#define pinmot3pwm  7  // pwm enable3
// motor 4
#define pinenc4A   38  // enc4A yellow
#define pinenc4B   39  // enc4B blue
#define pinmot4d1  40  // dir4-1   <<
#define pinmot4d2  41  // dir4-2
#define pinmot4pwm  6  // pwm enable4
// motor 5
#define pinenc5A   42  // enc5A yellow
#define pinenc5B   43  // enc5B blue
#define pinmot5d1  47  // dir5-1   <<
#define pinmot5d2  48  // dir5-2
#define pinmot5pwm  5  // pwm enable5
volatile long   motenc[MAXMOTORS]    = {0, 0, 0, 0, 0, 0},
                oldenc[MAXMOTORS]    = {0, 0, 0, 0, 0, 0};
byte pinmotdir[MAXMOTORS][ 2] = {
  {pinmot0d1, pinmot0d2},   // motor direction pin array
  {pinmot1d1, pinmot1d2},
  {pinmot2d1, pinmot2d2},
  {pinmot3d1, pinmot3d2},
  {pinmot4d1, pinmot4d2},
  {pinmot5d1, pinmot5d2},
int  pinmotpwm[MAXMOTORS] =      {pinmot0pwm, pinmot1pwm, pinmot2pwm,  // motor pwm pin array
                                  pinmot3pwm, pinmot4pwm, pinmot5pwm,
volatile int8_t ISRab[MAXMOTORS]     = {0, 0, 0, 0, 0, 0};
// 1/1 Auflösung
// 1/4 Auflösung
* Interrupt Handler Routine
void encHandler() {
  ISRab [ 0] <<= 2;
  ISRab [ 0] &= B00001100;
  ISRab [ 0] |= (digitalRead(pinenc0A) << 1) | digitalRead(pinenc0B);
  motenc[ 0] += schrittTab[ISRab[0]];           //
  ISRab [ 1] <<= 2;
  ISRab [ 1] &= B00001100;
  ISRab [ 1] |= (digitalRead(pinenc1A) << 1) | digitalRead(pinenc1B);
  motenc[ 1] += schrittTab[ISRab[1]];           //
  ISRab [ 2] <<= 2;
  ISRab [ 2] &= B00001100;
  ISRab [ 2] |= (digitalRead(pinenc2A) << 1) | digitalRead(pinenc2B);
  motenc[ 2] += schrittTab[ISRab[2]];           //
  ISRab [ 3] <<= 2;
  ISRab [ 3] &= B00001100;
  ISRab [ 3] |= (digitalRead(pinenc3A) << 1) | digitalRead(pinenc3B);
  motenc[ 3] += schrittTab[ISRab[3]];           //
  ISRab [ 4] <<= 2;
  ISRab [ 4] &= B00001100;
  ISRab [ 4] |= (digitalRead(pinenc4A) << 1) | digitalRead(pinenc4B);
  motenc[ 4] += schrittTab[ISRab[4]];           //
  ISRab [ 5] <<= 2;
  ISRab [ 5] &= B00001100;
  ISRab [ 5] |= (digitalRead(pinenc5A) << 1) | digitalRead(pinenc5B);
  motenc[ 5] += schrittTab[ISRab[5]];           //
  // motor pin settings
  // setup for L293D motor driver
     // motor 0
     pinMode(pinenc0A, INPUT_PULLUP);   // enc0A    yellow
     pinMode(pinenc0B, INPUT_PULLUP);   // enc0B    blue
     pinMode(pinmot0d1, OUTPUT);        // dir0-1
     pinMode(pinmot0d2, OUTPUT);        // dir0-2
     pinMode(pinmot0pwm ,OUTPUT);       // enable0
     // motor 1
     pinMode(pinenc1A, INPUT_PULLUP);   // enc1A    yellow
     pinMode(pinenc1B, INPUT_PULLUP);   // enc1B    blue
     pinMode(pinmot1d1, OUTPUT);        // dir1-1
     pinMode(pinmot1d2, OUTPUT);        // dir1-2
     pinMode(pinmot1pwm, OUTPUT);       // enable1
     // motor 2
     pinMode(pinenc2A, INPUT_PULLUP);   // enc2A    yellow
     pinMode(pinenc2B, INPUT_PULLUP);   // enc2B    blue
     pinMode(pinmot2d1, OUTPUT);        // dir2-1
     pinMode(pinmot2d2, OUTPUT);        // dir2-2
     pinMode(pinmot2pwm, OUTPUT);       // enable2
     // motor 3
     pinMode(pinenc3A, INPUT_PULLUP);   // enc3A     yellow
     pinMode(pinenc3B, INPUT_PULLUP);   // enc3B     blue
     pinMode(pinmot3d1, OUTPUT);        // dir3-1
     pinMode(pinmot3d2, OUTPUT);        // dir3-2
     pinMode(pinmot3pwm, OUTPUT);       // enable3
     // motor 4
     pinMode(pinenc4A, INPUT_PULLUP);   // enc4A     yellow
     pinMode(pinenc4B, INPUT_PULLUP);   // enc4B     blue
     pinMode(pinmot4d1, OUTPUT);        // dir4-1
     pinMode(pinmot4d2, OUTPUT);        // dir4-2
     pinMode(pinmot4pwm, OUTPUT);       // enable4
     // motor 5
     pinMode(pinenc5A, INPUT_PULLUP);   // encA5     yellow
     pinMode(pinenc5B, INPUT_PULLUP);   // encB5     blue
     pinMode(pinmot5d1, OUTPUT);        // dir5-1
     pinMode(pinmot5d2, OUTPUT);        // dir5-2
     pinMode(pinmot5pwm, OUTPUT);       // enable5
   Timer1.attachInterrupt(encHandler);
   Timer1.start(100); // Calls every ...µs
   Serial.println( "safety delay before start");
   delay(1000);  // safety delay before start
  while(true) {
     sprintf(sbuf, " 0=%6d, 1=%6d, 2=%6d, 3=%6d, 4=%6d, 5=%6d",
             motenc[ 0], motenc[ 1], motenc[ 2], motenc[ 3], motenc[ 4], motenc[ 5]);
     Serial.println(sbuf);
     delay(100);
If your encoders are high resolution, you can use only one interrupt per encoder and read only half the quadrature states available. You will need to read two pins per encoder in the ISR, but only one is set as an interrupt. Easily done with four pin change interrupts.
my timer-IRQ solution which I posted above works on the Mega for 16000 pin changes/s on all over 8x2= 16 encoder pins within a 200µs timer-IRQ.
for a faster rotation, the Timer IRQ intervall can be easily lowered to 1/10 (20µs) by no issues and not dropping any signal counts.
