Need a liquid pressure sensor
Hi i need an liquid pressure sensor with following requirements:
-1 to 1 bar
0-5V ouput analog or digital output
it should have a connection for a hose like this one:
VCC can be also 24V
I hope you can help me. I found no one.
Does it need to be cheap?
If cheap is important, there are a variety of poorly documented pressure sensors on Aliexpress. The specification of the materials used in their construction are also questionable. Maybe good enough for a hobby project.
What do you think is the difference between a liquid pressure sensor and a gas pressure sensor?
@johfi Hi Johfi,
Do you mean something like this?
https://amzn.eu/d/ddKwcT9
You would get a much better if we knew what the environment was and what liquid(s) it will be working with?
this is too big
nope it can be "expenisive".
it will work with inks for a printer on different bases (water, oil, etc)
@johfi How does the sensor looks like? Diameter? Length? Type? Screw?
What is supplying the pressure for the inks? Is it continuous pressure?
Guessing games do not work for me, without enough information I will just say good luck!
