Need advice with antenna selection for Xbee home/office automation project.
I have recently placed a few Xbees around the house (and intend to also place some in an industrial environment).
I am now trying to determine the best antenna(s) to use for these tasks.
I was thinking of connecting the coordinator to an 18dbi yagi located in the corner of the house.
However it would also possible that I could do an omni-direction antenna in the center of the house.
Would a full-wave "wifi" antenna work better than a half-wave or quarter-wave antenna?
I'm assuming that if communication between distant nodes becomes an issue then by adding a few routers every here and there should help?
Can I use any type of amplifier or multiple-antenna splitter?
Thanks!
A high gain antenna is very directional and bulky - given sufficient power levels you want an omni such as a 1/4 wave..
regards
Allan
megaBlocks:
If your Xbees are already running at the legal power limit for you part of the world (quite possible) then whilst you can use a yagi like that to increase reception range, if your transmitting through it your putting out some 60 times more power than you should.
The other issue with such a high gain antenna is that it will be highly directional, outside of a few degrees in the direction its pointing, stations either side might hear nothing.
If you need to increase gain\power on the Xbees by such a large margin, are the the right tool for the job ?
Which Xbees, what power are they transmitting at, which waveband, how big is the house,
does it have metal in the floors/walls (such as reinforced concrete), and what industrial
environment.
A range a few tens of meters shouldn't be any problem even with a broken antenna!
Highly directional antennas are suitable for point-to-point long-haul only.
