Need Development Board with Higher Speed & Memory by replacing Arduino Mega to interface the Arduino Ethernt shield 2 Board
Hi Sir,
Need Development Board with Higher capacity by replacing Arduino Mega to interface the Arduino Ethernet shield 2 Board. Can your Please suggest the Equivalent Development board with higher Capacity to interface the same Arduino Ethernet Shield 2 Development Board.
Why don't I understand this question?
It's not just you.
Pardon me! :nerd_face:
Do you know the purpose of a rethorical question?
Mega is a very good match for the Ethernet shield. the shield will not work faster with faster MCU
Higher capacity of what?
I need 1 serial port,1 i2c Port,1 spi port, Digital I/O - 10 Pins. Higher Speed and Higher memory to interface with Ethernet Shield 2 board. Have to replace Arduino Mega with pin-to-pin compatible.
Mega meets all these requirements, isn't it?
Yes. It meets all the requirements. For continual development, if we go for Pin-to-pin compatible higher end controller, it will be useful for my future development.
I couldnot find the spi port connector in the image which connects the arduino Ethernet Shield 2 board (Wiznet controller W5500)?
If I'm wrong, I'll be corrected by other members, but as far as I know, there is no pin-to-pin Mega-compatible controller with more resources than Mega itself.
There are two boards, compatible with Mega/Uno shields, more advanced than Mega - it are Arduino Due and Arduino Uno R4. But both of them are not pin-to-pin compatible with Mega.
I am planning to connect the 16 Nos of Mega + Ethernet shield 2 board to connect to my PC application using the Ethernet Port & Parallely Mega have to connect to the 8 Device via Serial port with RS-485 Port. Will it can be achieved in Mega? Kindly let us know
Ok. These boards Arduino Due and Arduino Uno R4 can be connected with Ethernet shield 2 board with the SPI Port as we did in the Mega? Will it support the Ethernet Shield 2 board and libraries?
Sorry, I have never worked with Ethernet Shield.
Ok. Experts can answer so that it will be useful for me to select the Future board as well.
Did you read and study the data sheets, didn´t you?
Sir. Right now i am working with Mega and Ethernet shied 2 board only. It is working perfectly. I am not sure the Ethernet shield 2 board & libraries will support for these boards Arduino Due and Arduino Uno R4. Kindly clarify.
This Document says that the Arduino Ethernet Shield libraries will support for UNO and Mega. The Datasheet does not says about these boards Arduino Due and Arduino Uno R4. Will it support for it? Kindly clarify.
I have the same information sources as you available.
