Need help locating an appropriate part
Hey all!
I am currently in the throes of creating a costume for a cosplay event.
TL;DR I need a way to create mist (because I am getting paid to do so that's why). I have used an ultrasonic piezoelectric disc like what you might find in a humidifier with some success, but I have encountered issues with this. The problem is, the disc has to stay at a VERY particular placement in the water reservoir or else it stops functioning.
Does anyone know where I might be able to find a submersible ultrasonic transducer of some sort that actually atomizes the water? Most components that I have found are used for industrial cleaning applications, and they don't create a fog or a mist. I need a disc that will still create mist when submerged.
Real mist? Most theatrical effects simulate mist with a fog machine.
Does it have to be heavier than air like real mist?
A non-pyrotechnic solution is to have a strip of tissue paper or cotton wool animated by a fan. Light that with red to make a flame effect or white for steam effect.
MorganS:
Yep! Real mist. Don't ask me; im just the maker, not the cosplayer. We did discuss the idea of hacking a fog machine but the weight+power requirements+gross fog juice generally took us away from that train of thought. Now the assumed method is to use an ultrasonic transducer in a water tank, but I can't find one that still functions while submerged.
Those piezo humidifier things are great. That seems like the best solution for those requirements. Now you just need a self-levelling reservoir.
"... but I can't find one that still functions while submerged."
You would need a Radio Flyer wagon to carry the batteries.
I saw some fo generator hacks which were made form an e-cig using ordinary fog juice, or 70/30 water/glycerin mixture.
water on dry ice?
scs_789:
how much mist do you need? I have seen a setup where they used a wick like whats in a highlighter to pull the water up to a ultrasonic transducer from the water tank
https://www.amazon.com/Portable-Humidifier-Personal-Whisper-Quiet-Adjustable/dp/B07RMGSSWN
