Hi, I’m a beginner working on my first electronics project – a 4x4x4 LED cube using an Arduino Nano. For the frame, I picked 14 AWG single-core copper wire.
My issue is that the solder just won’t stick to the copper wire. I tried sanding off the coating with sandpaper, and I’ve also tried both tin-lead solder and lead-free rosin core solder, but still no luck.
Did I pick the wrong wire size? Or am I doing something wrong with the soldering process? Any advice or beginner tips would really help me out. Thanks!
Use real lead solder with rosin core BUT I would also apply liquid flux, I use it all the time and my soldering goes quickly. Make sure the temp of your soldering iron is hot enough for the solder. I use 350C/700F. I use about 60/40 Sn/Pb
I think you could ask for a refund because not taking solder is definitely not ideal for electric application!
I think it may be enameled. Sanding off the enamel should allow easy soldering, if you truly have sanded off all the enamel.
I think you will know when you have sanded off all the enamel when it will take solder.
Another possibility: could this be enameled, copper-coated aluminium wire? If you sand off the enamel and the copper, the wire will look dull grey and will be difficult to solder.
Maybe. That is prety heavy gauge wire and if you have long pieces and several pieces to join, you neet to get it very hot in order for it to take solder. A 30W-50W iron won't do.
If it's a simple cube, then tin the wires first where they will connect. Now wrap one wire around the other and use a butane type torch to heat the joint hot enough to take a large diameter rosin core lead solder.
My 600 Ohm feed line which is 125 feet plus is all 14 AWG and coated with insulation, perhaps some type of nylon, no one uses enamel any more. It is perfectly good after 15 years in the weather. I had to scrape the insulation where solder was needed. That is also over 15 years old.
The OP needs to buy/use only tinned wire! Leave the bare copper until more experience is gained. I discovered some tinned copper wire I had for years was actually stainless steel and would not take solder at all.
@antonydarwin If it is BRASS, that explains his problem. The underpowered ill prepared surface will allow the zinc to oxidize and prevent the solder from sticking.
