Need help with Arduino mega code and NO2 2 click sensor
Hi, I am looking for someone to help me with ARDUINO code in relation to an Arduino mega and an MIKROE NO2 2 click sensor. I have attached a picture of the specific sensor. Thank you!
Welcome to the forum.
It helps to give a link to the product - so people can see full details:
On that page, there is a schematic of the board - so you can see exactly how it's connected-up:
There's also the datasheet for the sensor.
As the text tells you, the board uses an MCP3201 12-bit ADC by Microchip:
What help, exactly, do you need?
What have you tried so far?
TIP: Whenever you want to find Arduino code related to a thing, try putting "Arduino <thing>" into your favourite internet search engine; eg,
https://www.google.com/search?q=Arduino+MiCS-2714+sensor
Thanks a million, I have the sensor wired up correctly to the Arduino Mega I just need help with computing a code in order to generate values for NO2 concentration.
Heyah, as it happens I'm also working on getting this sensor working with Arduino. I'm getting some numbers out in the Serial Monitor, but I'm not 100% sure if it's correct or not. Any pointers would be greatly appreciated.
I'm using Arduino Mega 2560, as well as the sensor linked above.
The pins are connected as follows:
CS - 53
SCK - 52
SDO - 50
I had the PHT pin connected to PWM (pin 3), but I found it wasn't making a difference to anything, when connected or disconnected. If anyone could help me understand what this pin is/ how it should interact with the Arduino that would be greatly appreciated!
This is the code I've done so far:
#include <SPI.h>
// Define the SPI pins
 int pinCS = 53; // Chip Select (CS or SS) pin
 int pinSCK = 52; // SPI Clock (SCK) pin
 int spiMISO = 50; // MISO (Master In Slave Out) pin
// Define calibration constants for the sensor
 int Offset = 0;
 int Sensitivity = 2;
void setup(void)
  pinMode(pinCS, OUTPUT); // Set the CS HIGH - idle
  digitalWrite(pinCS, HIGH); // Set the CS HIGH - idle
 //start the SPI
  SPI.begin();
  SPI.setBitOrder( MSBFIRST );
  SPI.setDataMode( SPI_MODE3 );  // Modes 0-3 - collect data on different settings
  SPI.setClockDivider( SPI_CLOCK_DIV16 );
  digitalWrite(pinCS, LOW);  // Select the Sensor (as it collects data when low)
  // Read data from the sensor
  // using float instead of int to be able to obtain decimal places
  float(SensorValue) = SPI.transfer(0x00);
  digitalWrite(pinCS, HIGH);  // Deselect the Sensor
  Serial.print(SensorValue);
  // Convert the bytes to numbers
  float(SensorReading) = map(SensorValue, 0, 255, 0, 1023);
  //adjust for the sensitivity and calibration
  float(NO2_Conc) = (SensorReading - Offset)/Sensitivity;
  // Display the reading in the Serial Monitor
  Serial.print("Sensor Reading: ");
  Serial.print(NO2_Conc);
  Serial.println(" ppb");
  delay(1000);  // Frequency of sample rate
As I've said, this code provides me with numbers in the serial monitor every second. They jump from about 48 - 500, with very few values in between - This is why I'm doubting my code.
I'm quite new to Arduino and the forum so apologies for any obvious mistakes, and for my general lack of understanding. Any help is appreciated.
Cheers!
