I am new to using ESP32 boards in general, and I need help with the CameraWebServer example. I did not change anything besides to put my internet password and ssid and yet I am getting a compiling error. I am running Arduino IDE 2.0 with macOS. I am not using an FTDI cable, but an Arduino UNO and I'm running the recommended things in the "Tools" setting. Here is the error message: Multiple libraries were found for "WiFi.h"
Used: /Users/niko/Library/Arduino15/packages/esp32/hardware/esp32/1.0.1/libraries/WiFi
Not used: /private/var/folders/rs/djh9ph251kg3_bd99vcglbn00000gn/T/AppTranslocation/87445A99-2B63-4D84-A360-B1F9AC7A4136/d/Arduino.app/Contents/Java/libraries/WiFi
exec: "python": executable file not found in $PATH
Compilation error: exec: "python": executable file not found in $PATH
Can you describe what you exactly did? Take pen and paper and draw all connections between the two boards, take a photo of it and add it here in a post.
Just doing that does not automagically fix the python issue, you must have done more.
I suggest that you open a new topic about the compilation error in Programming Questions - Arduino Forum. Please post your code and full error message in that new topic; just in case, don't forget to use code tags.
Here is my drawing, it is pretty bad and anything that isn’t there, such as the 5V pin on the arduino, isn’t connected to anything. Also I’m not an expert with ESP32 boards so I just wrote whatever was on the board.
