Need Help with mini dfplayer
I am not very proficient with arduino, and i was trying to build an mp3 player using an Arduino Pro Micro and a mini dfplayer connected to a pair of earbuds.
i started with a simple code found on youtube to expand upon, but after briefly working it stopped working all of a sudden and now, while i can sometimes hear the static sound of the earbuds "working" when connecting them, music no longer plays
code:
#include "mp3tf16p.h"
MP3Player mp3(8,9);
mp3.initialize();
mp3.playTrackNumber(1,30);
mp3tf16p.h code:
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#define MP3_ERROR_ONLY 1
#define MP3_ALL_MESSAGE 2
class MP3Player
private:
SoftwareSerial *mySoftwareSerial;
void statusOnSerial(uint8_t type, int value);
void waitPlayIsTerminated(void);
int p_RX;
int p_TX;
public:
DFRobotDFPlayerMini player;
MP3Player(int RX, int TX);
~MP3Player();
void playTrackNumber(int trackNumber, int volume, boolean waitPlayTerminated = true);
boolean playCompleted(void);
void initialize(void);
int serialPrintStatus(int errorOnly);
MP3Player::MP3Player(int RX, int TX)
p_TX = TX;
p_RX = RX;
MP3Player::~MP3Player()
void MP3Player::initialize(void)
mySoftwareSerial = new SoftwareSerial(p_RX, p_TX);
mySoftwareSerial->begin(9600);
Serial.println(F("Initializing MP3Player ..."));
if (!player.begin(*mySoftwareSerial,true,false))
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while (true)
player.volume(10);
Serial.println(F("MP3Player online."));
void MP3Player::playTrackNumber(int trackNumber, int volume, boolean waitPlayTerminated)
player.volume(volume);
player.play(trackNumber);
if (waitPlayTerminated)
waitPlayIsTerminated();
void MP3Player::waitPlayIsTerminated(void)
while (!playCompleted())
boolean MP3Player::playCompleted(void)
if (player.available())
return player.readType() == DFPlayerPlayFinished;
return false;
// Print the detail message from DFPlayer to handle different errors and states.
int MP3Player::serialPrintStatus(int verbose)
uint8_t type = player.readType();
int value = player.read();
if (verbose == MP3_ERROR_ONLY)
if (type == DFPlayerError)
statusOnSerial(type, value);
if(type == DFPlayerError) {
return value;
return 0;
void MP3Player::statusOnSerial(uint8_t type, int value)
switch (type)
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value)
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
the Gnd and Vcc are all connected directly to the arduino pro micro,TX is connected to the 8 pin directly while RX is connected to pin 9 through a 1K Resistor
the ear jack should be wired to thre correct pins (not stereo) and to the gnd of the arduino
After you learn how to properly post , look into a library for that then look at the sample code. YT samples vary a lot in quality and often do not work at all.
If you use DFPlayerMini in I/O mode, you only need to send a short LOW signal to IO_1 or IO_2 to load the next or previous file. Hold that LOW a little longer on IO_1 or IO_2 to increase or decrease volume.
