Need help with parachute deploy system
Hi guys, I am having trouble with a parachute deploy system i am working on , it uses a push button to know when launch happens then delay a signal to a servo to deploy the parachute , it was working fine , but the button got pushed for too long??? it is supposed to move 180 degrees, but it now moves a total of 90 degrees in ever smaller increments (e.g. 40-30-20-10) , the servo is ok , button is fine, nothing fried on the board , any suggestions on what to do to fix it? Many thanks :smiley: , code and schematic are below
CODE:
#include <Servo.h>
const int servoPin = 8; // Servo pin
const int buttonPin = 9; // Pushbutton pin
int buttonState = 0;
int directionState = 0;
Servo myservo;
int pos = 0;
myservo.attach( 8 ); -Spaced cause when previewed it showed an emoji
pinMode(buttonPin, INPUT);
void loop(){
buttonState = digitalRead(buttonPin);
if (directionState == 0){
if (buttonState == HIGH) {
directionState = 1;
for(pos = 0; pos < 180; pos += 1)
myservo.write(pos);
delay(15); // waits 15ms to reach the position
} else if (directionState == 1) {
directionState = 0;
for (pos = 180; pos>=1; pos -=1)
myservo.write(pos);
delay(15);
It only did that because YOU FAILed to use code tags.
Why are you supplying 3.3V to the switch?
You aren't really powering the servo from the Arduino, are you?
