noxx2
August 29, 2024, 8:01am
1
Hello,
Yesterday the IDE showed me an update of the board, which I did (->ESP32).
Then I uploaded the code for the ESP32 and nothing worked anymore. My LED matrix (32x8) no longer displayed anything.... All LEDs dead.
At first I thought something had broken, so I first replaced the ESP32 -> nothing
Then replaced the LED matrix -> nothing
Then tested the sample codes, with matixtest.ino at least some light.
The first 5 pixels show H-O-W-D-Y
So changed the sample code to 32 pixels -> Nothing, no LED lights up
So, tested step by step, up to 9x8 it works, from 10x8 no LED lights up...
This one still works:
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(9, 8, PIN,
NEO_MATRIX_TOP + NEO_MATRIX_RIGHT +
NEO_MATRIX_COLUMNS + NEO_MATRIX_PROGRESSIVE,
NEO_GRB + NEO_KHZ800);
this not:
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(10, 8, PIN,
I've since thrown everything for the Arduino down and reinstalled it, but it remains.....
Roll back the ESP32 board files to the previous version
If the problem arose from the core update, reinstall the previous version and don't worry. Maybe there's a bug in the new version
noxx2
August 29, 2024, 11:50am
4
Installing a different IDE or board version did not help.
xfpd
August 29, 2024, 4:49pm
5
noxx2:
How do five neopixels display five letters? A pixel is a dot. You lost me.
If changing the board and changing the matrix do not change the result, look at wiring and power. ESP32 are known for running hobby Neopixels, so I would guess that ability is tested before releasing a new core.
noxx2:
9x8 no LED lights up... This one still works (9x8... You lost me again.
noxx2
August 29, 2024, 5:18pm
6
i found the error. it seems there is a bug in eps32 libary
i ve no problems with versions until 2.17.
all version of 3.x dont work correctly
b707
August 29, 2024, 10:30pm
7
They was advised you the same in posts #3 #4
