NeoPixel stops Refreshing after Array Usage
As soon as i add in a if statement to gather data from an array the pixels stop refreshing.
This could look like this:
if(array[x][y]==true){
pixels.setPixelColor(getIndex(x, y),0, 200, 0);
After adding that into my code, the pixels stoped refreshing after the upload.
Hope somebody knows how to resolve this issue.
I moved your topic to an appropriate forum category @derbrummer.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Post the code, or post a minimal compilable we can run it for ourselves it demonstrates your issue sketch.
With no context whatsoever, there could be many things to explain this.
Certainly if statements, arrays and functions are still known to be working quite well. :expressionless:
Welcome to the community, BTW.
a7
As a first step, try adding a serial debug statement like
Serial.print("array value is ");
Serial.println(array[x][y]);
Also print out the value of getIndex(x, y), x, and y. Writing outside the bounds of an array is a common reason for code to start misbehaving.
As soon as I put the key in the ignition and turn it, the car does not start. Hmm, battery flat? Or no petrol? Or ...
Translated to your problem:
Out of memory? Or writing outside boundaries of array? Or ...
Please post your full code (please use code tags as described in How to get the best out of this forum).
Also please let us know which Arduino you are using.
Alright, firstly thanks everyone for the quick responses and suggestions.
A little more context: im building a little arcade machine with a 11x15 neopixel matrix, an arduino nano 168 and a controller (just 6 buttons hooked up to digital ports) to move up, down, left, right, a game selection and a confirm button.
I want there to be 3 games on that arcade, and ive gotten the game selection and a tic tac toe game running. Now i want to have Snake on it. I managed to get a pixel to move around with the use of the controller, spawn fruit which the snake "consumes" when in contact, which then increases the snakes length varaible, but doesnt actually make it longer yet. I want to use a 2 dimensional array to store the information on where the snakes body parts are at to start makeing the snake longer.
Now, at the end of the code, now as soon as i add a function to check or write to that array and upload that new code the display refuses to refresh. Besides that the code still works in the background, which iwas able to see by adding serial debug statements when entering a game or a menue select.
Here the Code, at the end is an example of my problem:
//Anzahl LED's und Ausgang vom ESP festlegen
#define PIN         10 //DigitalPin 12
#define NUMBERS     165 //Menge LEDs 0-165 (166stck)
//Adresse der ersten und letzten LED
const int ersteLED = 0;
const int letzteLED = 164;
int x = 0;
int y = 0;
short activePlayer=0; //0 Kreuz / 1 Kreis
int red = 80;
int green = 80;
int blue = 80;
int TTTAltxFledIndex;
short TTTRotPunkte=0;
short TTTBlauPunkte=0;
short TTTZugZahl=0;
int TTTFeldIndex =0;
int TTTFelderMitte[3][3]{
{130,126,122},
{86,82,78},
{42,38,34}
int TTTFelderVergeben[3][3]{ //0 nicht - 1=Kreuz - 4= Kreis
{0,0,0},
{0,0,0},
{0,0,0}
short SnakeRichtung=0; //0Up 1R 2L 3Down
short SnakeLength=1;
bool SnakeGegessen=false;
short fy;
short fx;
bool SnakeBody[11][11];
int oldx = 0;
int oldy = 0;
int numPins = 6;
int pins[] = {0, 0, 0, 0, 0, 0};  // Pin-Nummern
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMBERS, PIN, NEO_GRB + NEO_KHZ800);
//Berechnung des Pixelindex mit x&y
int getIndex(int x, int y) {
  int offset = 0;
  if(y % 2 != 0) {
    // Jede zweite Zeile geht von rechts aus
    offset = 10;
    x = -x;
  return y * (11) + x + offset;
 Serial.begin(19200);
 pixels.begin();
 pixels.clear();
 pixels.show();
  for (int i = 2; i <= 7; i++) {
    pinMode(pins[i], INPUT);
  for(short b=0; b<=10; b++){
    for(short c=0; c<=10; c++){
      SnakeBody[b][c]=false;
  Menue();
void TTTSpiel(){
  TTTFeldStreben();
  TTTPunkteZeichnen();
  TTTFeldWahl();
void inputLesen(){
    pins[i-2]=digitalRead(i);
void TTTFeldStreben() { //Zeichnet Raster
  int red = 80;
  int green = 80;
  int blue = 80;
  x = 1;
  y = 0;
  // Querstreben
  for (int i = 0; i <= 3; i++) {
    x = 1 + i * 4;
    for (int spalte = 0; spalte <= 10; spalte++) {
      y = spalte;
      pixels.setPixelColor(getIndex(y, x), red, green, blue);
  for (int i = 3; i <= 7; i += 4) {
  for (int reihe = 1; reihe <= 13; reihe++) {
    y = i;
    x = reihe;
  pixels.show();
void TTTFeldWahl(){
  int x=1;
  int y=1;
  bool done=false;
  while(done==false){
  pixels.setPixelColor(getIndex(3, 11),80,80,80); //BugAuslgiech fehlender Pixel
  pixels.show();
  pixels.setPixelColor(TTTFeldIndex,0,0,0);
  inputLesen();
  if(pins[0]==1){y--;}
  if(pins[3]==1){y++;}
  if(pins[1]==1){x--;}
  if(pins[2]==1){x++;}
  if(pins[4]==1){Menue();}
  if(x>2){x=2;}
  if(x<0){x=0;}
  if(y>2){y=2;}
  if(y<0){y=0;}
  delay(140);
  TTTFeldIndex=TTTFelderMitte[y][x];
  if(activePlayer==0){pixels.setPixelColor(TTTFeldIndex,150,70,0);}else{pixels.setPixelColor(TTTFeldIndex,0,100,100);}
  pixels.show();
  if(TTTFelderVergeben[y][x]==0){//FeldvonKreuz
    if(pins[5]==1){done=true;}
    if(activePlayer==1){
      TTTKreisZeichnen();
      TTTFelderVergeben[y][x]=4;
      else{
        TTTKreuzZeichnen();
        TTTFelderVergeben[y][x]=1;
  TTTCheckSieger();
  TTTSpiel();
void TTTPunkteZeichnen(){
  if(TTTRotPunkte==12 || TTTBlauPunkte==12){
    TTTRotPunkte=0;
    TTTBlauPunkte=0;
    } //volle Punkte bereits erreicht
  short i=0;
  //RotePunkteZeichen
  if(TTTRotPunkte>0){
    while(i<TTTRotPunkte){
      pixels.setPixelColor(i,200,0,0);
      i++;
  i=0;
  if(TTTBlauPunkte>0){
    while(i<TTTBlauPunkte){
      pixels.setPixelColor(i+154,0,0,200);
      i++;
void TTTCheckSieger(){ //Sieg Blau =12 Sieg Rot=3
  bool spiellauft=true;
  if(
    TTTFelderVergeben[2][2] + TTTFelderVergeben[2][1] + TTTFelderVergeben[2][0] == 3 || //HReiheUnten
    TTTFelderVergeben[1][2] + TTTFelderVergeben[1][1] + TTTFelderVergeben[1][0] == 3 || //HReiheMitte
    TTTFelderVergeben[0][2] + TTTFelderVergeben[0][1] + TTTFelderVergeben[0][0] == 3 || //HReiheOben
    TTTFelderVergeben[2][2] + TTTFelderVergeben[1][2] + TTTFelderVergeben[0][2] == 3 || //VReiheRechts
    TTTFelderVergeben[2][1] + TTTFelderVergeben[1][1] + TTTFelderVergeben[0][1] == 3 || //VReiheMitte
    TTTFelderVergeben[2][0] + TTTFelderVergeben[1][0] + TTTFelderVergeben[0][0] == 3 || //VReiheLinks
    TTTFelderVergeben[2][2] + TTTFelderVergeben[1][1] + TTTFelderVergeben[0][0] == 3 || //ReiheUR nach OL
    TTTFelderVergeben[2][0] + TTTFelderVergeben[1][1] + TTTFelderVergeben[0][2] == 3 //ReiheUL nach OR
      TTTRotPunkte++;
      if(TTTRotPunkte==11){TTTBildReset();}
      TTTBildReset();
      activePlayer=1;
  if(
    TTTFelderVergeben[2][2] + TTTFelderVergeben[2][1] + TTTFelderVergeben[2][0] == 12 || //HReiheUnten
    TTTFelderVergeben[1][2] + TTTFelderVergeben[1][1] + TTTFelderVergeben[1][0] == 12 || //HReiheMitte
    TTTFelderVergeben[0][2] + TTTFelderVergeben[0][1] + TTTFelderVergeben[0][0] == 12 || //HReiheOben
    TTTFelderVergeben[2][2] + TTTFelderVergeben[1][2] + TTTFelderVergeben[0][2] == 12 || //VReiheRechts
    TTTFelderVergeben[2][1] + TTTFelderVergeben[1][1] + TTTFelderVergeben[0][1] == 12 || //VReiheMitte
    TTTFelderVergeben[2][0] + TTTFelderVergeben[1][0] + TTTFelderVergeben[0][0] == 12 || //VReiheLinks
    TTTFelderVergeben[2][2] + TTTFelderVergeben[1][1] + TTTFelderVergeben[0][0] == 12 || //ReiheUR nach OL
    TTTFelderVergeben[2][0] + TTTFelderVergeben[1][1] + TTTFelderVergeben[0][2] == 12 //ReiheUL nach OR
      TTTBlauPunkte++;
      if(TTTBlauPunkte==11){TTTBildReset();}
      TTTBildReset();
      activePlayer=0;
  for (int i = 0; i < 3 && spiellauft==true; i++) { //unentschieden
    for (int j = 0; j < 3 && spiellauft==true; j++) {
      if(TTTFelderVergeben[i][j] == 0){
        spiellauft=false;
  if(spiellauft==true) {
    TTTBildReset();
void TTTBildReset(){
  pixels.clear();
    //ArrayMit0FĂĽllen
  for (int i = 0; i < 3; i++) {
    for (int j = 0; j < 3; j++) {
      TTTFelderVergeben[i][j] = 0;
  delay(200);
void TTTKreuzZeichnen(){
  if(TTTFeldIndex==126 || TTTFeldIndex==82 || TTTFeldIndex==38){//Mitte
    pixels.setPixelColor(TTTFeldIndex+1,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-1,100,0,0);
    pixels.setPixelColor(TTTFeldIndex+12,100,0,0);
    pixels.setPixelColor(TTTFeldIndex+11,100,0,0);
    pixels.setPixelColor(TTTFeldIndex+10,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-11,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-12,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-10,100,0,0);
    if(TTTFeldIndex==130 || TTTFeldIndex==86 || TTTFeldIndex==42){//Links
      pixels.setPixelColor(TTTFeldIndex+2,100,0,0);
      pixels.setPixelColor(TTTFeldIndex+3,100,0,0);
      pixels.setPixelColor(TTTFeldIndex+4,100,0,0);
      pixels.setPixelColor(TTTFeldIndex-18,100,0,0);
      pixels.setPixelColor(TTTFeldIndex-19,100,0,0);
      pixels.setPixelColor(TTTFeldIndex-20,100,0,0);
    if(TTTFeldIndex==122 || TTTFeldIndex==78 || TTTFeldIndex==34){//Rechts
      pixels.setPixelColor(TTTFeldIndex+18,100,0,0);
      pixels.setPixelColor(TTTFeldIndex+19,100,0,0);
      pixels.setPixelColor(TTTFeldIndex+20,100,0,0);
      pixels.setPixelColor(TTTFeldIndex-2,100,0,0);
      pixels.setPixelColor(TTTFeldIndex-3,100,0,0);
      pixels.setPixelColor(TTTFeldIndex-4,100,0,0);
    if(TTTFeldIndex==124){
    pixels.setPixelColor(TTTFeldIndex+14,100,0,0);
    pixels.setPixelColor(TTTFeldIndex+15,100,0,0);
    pixels.setPixelColor(TTTFeldIndex+16,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-6,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-7,100,0,0);
    pixels.setPixelColor(TTTFeldIndex-8,100,0,0);
  activePlayer=1;
  pixels.show();
void TTTKreisZeichnen(){
    pixels.setPixelColor(TTTFeldIndex+1,0,0,100);
    pixels.setPixelColor(TTTFeldIndex-1,0,0,100);
    pixels.setPixelColor(TTTFeldIndex+12,0,0,100);
    pixels.setPixelColor(TTTFeldIndex+11,0,0,100);
    pixels.setPixelColor(TTTFeldIndex+10,0,0,100);
    pixels.setPixelColor(TTTFeldIndex-11,0,0,100);
    pixels.setPixelColor(TTTFeldIndex-12,0,0,100);
    pixels.setPixelColor(TTTFeldIndex-10,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+2,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+3,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+4,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-18,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-19,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-20,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+18,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+19,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+20,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-2,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-3,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-4,0,0,100);
    if(TTTFeldIndex==128){
      pixels.setPixelColor(TTTFeldIndex+6,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+7,0,0,100);
      pixels.setPixelColor(TTTFeldIndex+8,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-14,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-15,0,0,100);
      pixels.setPixelColor(TTTFeldIndex-16,0,0,100);
  activePlayer=0;
  pixels.show();
void Menue(){
 MenueZeichnen();
 MenueAuswahl();
void MenueZeichnen(){
  TTTBildReset();
  // Querstreben
    x = 1 + i * 4;
      y = spalte;
  //TicTacToe Auswahl zeichnen
  TTTFeldIndex=124;
  TTTKreuzZeichnen();
  TTTFeldIndex=128;
  TTTKreisZeichnen();
  //Schlange Zeichnen
  for(short b; b<5;b++){
    pixels.setPixelColor(getIndex(b+2, 3), 0, 120, 0);
  pixels.setPixelColor(getIndex(8, 3), 120, 0, 0);
  pixels.show();
void MenueAuswahl(){
  bool bestaetigt=false;
  short k=0;
  while(bestaetigt==false){
    inputLesen();
    if(pins[0]==1){k--;MenueZeichnen();}
    if(pins[3]==1){k++;MenueZeichnen();}
    if(pins[5]==1){bestaetigt=true;}
    if(k>2){k=0;}
    if(k<0){k=2;}
    delay(140);
    if(k==0){//TTT
    pixels.setPixelColor(getIndex(0, 10),128, 0, 128);
    pixels.setPixelColor(getIndex(0, 11),128, 0, 128);
    pixels.setPixelColor(getIndex(0, 12),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 10),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 11),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 12),128, 0, 128);
  if(k==1){//4Cnct
    pixels.setPixelColor(getIndex(0, 6),128, 0, 128);
    pixels.setPixelColor(getIndex(0, 7),128, 0, 128);
    pixels.setPixelColor(getIndex(0, 8),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 6),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 7),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 8),128, 0, 128);
  if(k==2){//Snake
    pixels.setPixelColor(getIndex(0, 2),128, 0, 128);
    pixels.setPixelColor(getIndex(0, 3),128, 0, 128);
    pixels.setPixelColor(getIndex(0, 4),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 2),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 3),128, 0, 128);
    pixels.setPixelColor(getIndex(10, 4),128, 0, 128);
  pixels.show();
  x=1;
  y=1;
  pixels.clear();
  if(k==0){//TTT
      TTTSpiel();
  if(k==1){//4Cnct
    TTTSpiel();
  if(k==2){//Snake
    SnakeSpiel();
void SnakeSpiel(){
  SnakeBildReset();
  SnakeFruchtSpawn();
  SnakeBewegen();
void SnakeBildReset(){
  pixels.clear();
  for (int i = 0; i <= 3; i++){
    x = 1 + i * 12;
      y = spalte;
  pixels.show();
void SnakeBewegen(){
  x=5;
  y=7;
  SnakeRichtung=5;
  while(pins[4]==0){
    SnakeEssenCheck();
    if(SnakeGegessen==true){
     SnakeLength = SnakeLength +1;
     SnakeGegessen =false;
     SnakeFruchtSpawn();
     Serial.println(SnakeLength);
    SnakeInputs();
    pixels.setPixelColor(getIndex(x, y),0, 100, 0);
    pixels.show();
    delay(100);
    pixels.setPixelColor(getIndex(x, y),0, 0, 0);
    pixels.show();
void SnakeEssenCheck(){
  if(fx==x && fy == y){
    SnakeGegessen=true;
void SnakeFruchtSpawn(){
  fx = random(0, 11);
  fy = random(2, 13);
  if(fx != x || fy != y){
    pixels.setPixelColor(getIndex(fx, fy),100, 0, 0);
void SnakeInputs(){//0Up 1R 2L 3Down
  inputLesen();
  if(pins[0]==1 && SnakeRichtung != 3){SnakeRichtung=0;}
  if(pins[3]==1 && SnakeRichtung != 0){SnakeRichtung=3;}
  if(pins[1]==1 && SnakeRichtung != 1){SnakeRichtung=2;}
  if(pins[2]==1 && SnakeRichtung != 2){SnakeRichtung=1;}
  if(SnakeRichtung==0){
    y++;
    if(y>12) {y=2;}
  if(SnakeRichtung==3){
    y--;
    if(y<2) {y=12;}
  if(SnakeRichtung==2){
    x--;
    if(x<0) {x=10;}
  if(SnakeRichtung==1){
    x++;
    if(x>10) {x=0;}
//Examplfe of crash code
    //if(SnakeBody[x][y]==true){
    //  Menue();
You problem is not a using the array, your problem is calling the Menue() function.
Below the logical tree of the calling SnakeInputs() - the function where the problem code is located :
Menue() ->
  MenueAuswahl() ->
       SnakeSpiel() ->
         SnakeBewegen() ->
                   SnakeInputs()  -> Menue()
Ultimately, through several intermediate levels, you try to call the Menue() function from itself. This is called recursion, and you can only use it if you clearly understand what you are doing.
In your code, you use it to return to the main menu in order to select a new menu item again later. You can't do that. This is actually an infinite loop and it is guaranteed to lead to a program hang, which is what happens to you.
You need to change the logic of working with the menu. Instead of calling a new Menue() instance from the SnakeInputs(), you should return to first Menue() by exiting each lower function to the higher one sequentially.
Hello. Thanks for your anwser. Sorry im fairly new to working with the arduino so i guess these things happen.
Recursion might have been the problem, but i was too lazy to find all the mistakes in that code to fix that...so i rewrote the whole thing (menue and tictactoe work) but i run into the same problem with snake now.
Ive tried avoiding recursion as much as i can, but i can`t tell if i did the same mistake again.
When trying to call the
line 459 - SnakeBodyPositionsSetzen(); function the leds freeze again. This function simply sets the first value of an array to 1 for now.
int x = 0;
int y = 0;
short TTTFelder[3][3]{ //0 nicht - 1=Kreuz - 4= Kreis
{0,0,0},
{0,0,0},
{0,0,0}
short TTTAktuellerSpieler =0; //0Rot 1 Blau
short TTTSpielLaenge=0;
short SnakeLength = 1;
int SnakeBody[122];
short SnakeRichtung =0; //1up 2down 3left 4 right
int red = 80;
int green = 80;
int blue = 80;
int numPins = 6;
  int offset = 0;
  if(y % 2 != 0) {
    offset = 10;
    x = -x;
 pixels.begin();
 pixels.clear();
 pixels.show();
  switch(Menue()){
    case 0:
    Serial.println("Snake");
    SnakeSpiel();
    case 1:
    Serial.println("mitte");
    case 2:
    Serial.println("TTT");
    TTTSpiel();
short InputRueckgabe(){
  short InputWahl = 0;
  if(pins[0]==1){InputWahl=1;}//up
  if(pins[3]==1){InputWahl=2;}//down
  if(pins[1]==1){InputWahl=3;}//left
  if(pins[2]==1){InputWahl=4;}//right
  if(pins[4]==1){InputWahl=6;}//confirm
  if(pins[5]==1){InputWahl=5;}//menue
  return InputWahl;
short Menue(){
  short Auswahl=0; // 0 nichts, 1 TTT, 2 Snake , 3 dunno
  MenueZeichnen();
  Auswahl=MenueAuswahl(); //loop bis confirm
  return Auswahl;
  pixels.clear();
  // Querstreben
    x = 1 + i * 4;
      y = spalte;
    //Schlange Zeichnen
  for(short b=0; b<5;b++){
    //TTTZeichnen
  TTTBlauZeichnen(3,11);
  TTTRotZeichnen(7,11);
  pixels.show();
short MenueAuswahl(){//loop bis confirm
  short b=1;
  bool Confirm=false;
  while(Confirm==false){
  switch(InputRueckgabe()){
    default: break; //noInput
    case 1://up
    b++;
    if(b>2){b=0;}
    case 2://down
    b--;
    if(b<0){b=2;}
    case 5:
    Confirm=true;
  MenueZeichnen();
    if(b==2){//TTT
  if(b==1){//4Cnct
  if(b==0){//Snake
  pixels.show();
  delay(150);
  return b;
void TTTSpiel(){
  short input=0;
  x=2;
  y=2;
  bool TTTKomplettVorbei=false;
  bool TTTRundeVorbei=false;
  while(TTTKomplettVorbei==false){
  TTTReset();
  TTTRasterZeichnen();
  x=5;
  y=7;
    while(TTTRundeVorbei==false){
      pixels.setPixelColor(getIndex(x,y),0,0,0);
      input=InputRueckgabe();
      if(input==1){y=y+4;}
      if(input==2){y=y-4;}
      if(input==3){x=x-4;}
      if(input==4){x=x+4;}
      if(x>9){x=1;}
      if(x<1){x=9;}
      if(y>11){y=3;}
      if(y<3){y=11;}
      if(TTTAktuellerSpieler==0){
        pixels.setPixelColor(getIndex(x,y),100,50,0);
        pixels.show();
      if(TTTAktuellerSpieler==1){
        pixels.setPixelColor(getIndex(x,y),0,100,100);
        pixels.show();
      delay(150);
      if(input==5){
        TTTFeldEinnehmen(x,y);
          if(TTTCheckSieger()==true){
          TTTRundeVorbei=true;
      if(input==6){
        TTTSpielLaenge=0;
        TTTRundeVorbei==true;
        TTTKomplettVorbei=true;
void TTTFeldEinnehmen(short xx, short yy){
  short tempx=xx;
  short tempy=yy;
  if(xx==1){xx=0;}
  if(xx==5){xx=1;}
  if(xx==9){xx=2;}
  if(yy==11){yy=0;}
  if(yy==7){yy=1;}
  if(yy==3){yy=2;}
  if(TTTFelder[yy][xx]==0){
    switch(TTTAktuellerSpieler){
      case 0:
      TTTRotZeichnen(tempx, tempy);
      TTTAktuellerSpieler=1;
      TTTFelder[yy][xx]=1;
      TTTSpielLaenge=TTTSpielLaenge+1;
      x=5;
      y=7;
      case 1:
      TTTBlauZeichnen(tempx,tempy);
      TTTAktuellerSpieler=0;
      TTTFelder[yy][xx]=4;
      x=5;
      y=7;
bool TTTCheckSieger(){
  bool Sieg=false;
  if(
      TTTFelder[2][2] + TTTFelder[2][1] + TTTFelder[2][0] == 3 || //HReiheUnten
      TTTFelder[1][2] + TTTFelder[1][1] + TTTFelder[1][0] == 3 || //HReiheMitte
      TTTFelder[0][2] + TTTFelder[0][1] + TTTFelder[0][0] == 3 || //HReiheOben
      TTTFelder[2][2] + TTTFelder[1][2] + TTTFelder[0][2] == 3 || //VReiheRechts
      TTTFelder[2][1] + TTTFelder[1][1] + TTTFelder[0][1] == 3 || //VReiheMitte
      TTTFelder[2][0] + TTTFelder[1][0] + TTTFelder[0][0] == 3 || //VReiheLinks
      TTTFelder[2][2] + TTTFelder[1][1] + TTTFelder[0][0] == 3 || //ReiheUR nach OL
      TTTFelder[2][0] + TTTFelder[1][1] + TTTFelder[0][2] == 3 //ReiheUL nach OR
      TTTRotPunkte++;
      TTTSpielLaenge=0;
      Sieg=true;
      return Sieg;
  if(
      TTTFelder[2][2] + TTTFelder[2][1] + TTTFelder[2][0] == 12 || //HReiheUnten
      TTTFelder[1][2] + TTTFelder[1][1] + TTTFelder[1][0] == 12 || //HReiheMitte
      TTTFelder[0][2] + TTTFelder[0][1] + TTTFelder[0][0] == 12 || //HReiheOben
      TTTFelder[2][2] + TTTFelder[1][2] + TTTFelder[0][2] == 12 || //VReiheRechts
      TTTFelder[2][1] + TTTFelder[1][1] + TTTFelder[0][1] == 12 || //VReiheMitte
      TTTFelder[2][0] + TTTFelder[1][0] + TTTFelder[0][0] == 12 || //VReiheLinks
      TTTFelder[2][2] + TTTFelder[1][1] + TTTFelder[0][0] == 12 || //ReiheUR nach OL
      TTTFelder[2][0] + TTTFelder[1][1] + TTTFelder[0][2] == 12 //ReiheUL nach OR
      TTTBlauPunkte++;
      TTTSpielLaenge=0;
      Sieg=true;
      return Sieg;
    if(TTTSpielLaenge==9){
      TTTSpielLaenge=0;
      Sieg=true;
      return Sieg;
  Sieg=false;
  return Sieg;
void TTTRasterZeichnen(){
  pixels.clear();
  // Querstreben
    x = 1 + i * 4;
      y = spalte;
  //Hochstreben
    y = i;
    x = reihe;
 pixels.show();
void TTTReset(){
  for(short j=0;j<3;j++){
    for(short i=0;i<3;i++){
      TTTFelder[j][i]=0;
    TTTRotPunkte=0;
    TTTBlauPunkte=0;
  short i=0;
  //RotePunkteZeichen
  if(TTTRotPunkte>0){
      i++;
  i=0;
      i++;
void TTTBlauZeichnen(short x, short y){
  pixels.setPixelColor(getIndex(x+1,y+1), 0, 0, 100);
  pixels.setPixelColor(getIndex(x-1,y+1), 0, 0, 100);
  pixels.setPixelColor(getIndex(x+1,y-1), 0, 0, 100);
  pixels.setPixelColor(getIndex(x-1,y-1), 0, 0, 100);
  pixels.setPixelColor(getIndex(x+1,y), 0, 0, 100);
  pixels.setPixelColor(getIndex(x-1,y), 0, 0, 100);
  pixels.setPixelColor(getIndex(x,y+1), 0, 0, 100);
  pixels.setPixelColor(getIndex(x,y-1), 0, 0, 100);
  delay(30);
void TTTRotZeichnen(short x, short y){
  pixels.setPixelColor(getIndex(x+1,y+1), 100, 0, 0);
  pixels.setPixelColor(getIndex(x-1,y+1), 100, 0, 0);
  pixels.setPixelColor(getIndex(x+1,y-1), 100, 0, 0);
  pixels.setPixelColor(getIndex(x-1,y-1), 100, 0, 0);
  pixels.setPixelColor(getIndex(x+1,y), 100, 0, 0);
  pixels.setPixelColor(getIndex(x-1,y), 100, 0, 0);
  pixels.setPixelColor(getIndex(x,y+1), 100, 0, 0);
  pixels.setPixelColor(getIndex(x,y-1), 100, 0, 0);
  delay(30);
void SnakeReset(){
  pixels.clear();
  // Querstreben
    x = 1 + i * 12;
      y = spalte;
  pixels.show();
  x=5;
  y=7;
  SnakeRichtung =0;
  SnakeLength =1;
void SnakeSpiel(){//SnakeRichtung =0; //1up 2down 3left 4 right
  SnakeReset();
  bool zueruckMenue =false;
  while(zueruckMenue==false){
    switch(InputRueckgabe()){//Richtung ermitteln
    case 1://up
    if(SnakeRichtung !=2){
      SnakeRichtung =1;
    case 2://down
    if(SnakeRichtung !=1){
    SnakeRichtung =2;
    case 3://left
    if(SnakeRichtung !=4){
    SnakeRichtung =3;
    case 4://right
    if(SnakeRichtung !=3){
    SnakeRichtung =4;
    case 5://confirm
    case 6://menue
      zueruckMenue = true;
    switch(SnakeRichtung){//nächste x/y koordinate mit Richtung bestimmen. Korrektur für überschuss
    case 1://up
    y++;
    if(y>12){
    y =2;
    case 2://down
    y--;
    if(y<2){
    y =12;
    case 3://left
    x--;
    if(x<0){
    x =10;
    case 4://right
    x++;
    if(x>10){
    x =0;
    //SnakeBodyPositionsSetzen();
    SnakeBodyZeichnen();
  short fx;
  short fy;
  fx = random(0, 11);
  fy = random(2, 13);
void SnakeBodyPositionsSetzen(){
  SnakeBody[0]=1;
void SnakeBodyZeichnen(){
  for(short j=0;j<121;j++){
    if(SnakeBody[j]!=0){
      pixels.setPixelColor(SnakeBody[j],0,100,0);
    if(SnakeBody[j]==0){
    pixels.setPixelColor(SnakeBody[j],0,0,0);
  pixels.show();
void SnakeBodyPositionsSetzen(short xx,short yy){
  if(SnakeLength<121){
  for(short i=SnakeLength;i>0;i--){
    SnakeBody[i]=SnakeBody[i-1];
  SnakeBody[0]=getIndex(xx, yy);
 Serial.println(SnakeBody[0]);
Using the serial print and blindly navigating to the game i can see that the correct Numbers are being written to the Array:
16:42:53.730 -> slot0: 87 slot1: 77 slot2: 78
16:42:53.902 -> slot0: 86 slot1: 87 slot2: 77
16:42:54.041 -> slot0: 85 slot1: 86 slot2: 87
16:42:54.198 -> slot0: 84 slot1: 85 slot2: 86
16:42:54.355 -> slot0: 83 slot1: 84 slot2: 85
16:42:54.493 -> slot0: 82 slot1: 83 slot2: 84
16:42:54.664 -> slot0: 81 slot1: 82 slot2: 83
16:42:54.803 -> slot0: 80 slot1: 81 slot2: 82
16:42:54.960 -> slot0: 79 slot1: 80 slot2: 81
16:42:55.117 -> slot0: 78 slot1: 79 slot2: 80
Juding by the numbers it is moving the body parts of the snake in the correct manner.
Unless you have collisions, a snake doesn't need that. You only need to store the head and tail position. Each iteration, you add a head pixel and delete a tail pixel.
True, but the snake needs collision with itself. An im guessing the Array should not be the problem.
For that, yes you need to store all positions. You will need a circular buffer.
