No port COM create
I have install IDE Arduino, I have link my Arduino Due on port USB (native and programming port) but my computer doesn't recognise anything.
I can't communicate with the Due. I try to install manually the Port "Arduino Due" and "Arduino Due programming" but the computer fall to start the periphery (code 10).
I'm on Windows 11.
PS: Sorry for my English
Have you looked in the Device Manager - are the two COM ports actually appearing there?
No, i have nothing.
The Due has micro-USB connectors. Micro-USB cables come in two flavours; charge-only and data/sync.
My guess is that you're using a charge-only cable.
Yes - that'd be the first thing to check!
I found a other cable but it doesn't work any more, i will got a new cable tomorrow.
NB: the Due work with an old program i have upload since many years with a other computer.
Do any of your cables work with any other devices? Or is it just the DUE that doesn't work?
i had on around 10 cables in here.... all charge only :slight_smile: But the cable from my car navigation worked fine. If you have a old digital camera, the cable should work well, too
I haven't no device for test but i buy a cable, it will be delivered tomorrow.
Thanks.
It's all right !
Thanks :slight_smile:
You mean the new cable fixed it?
You've marked post #3 as the Solution - but that post tells us nothing about how you solved the problem!
Sorry, it was a mistake.
The new cable fixed it.
