Not recieving data via SPI on ESP-wroom-32 from Teensy 4.1
At the very least I am sending the letter "C" from the Teensy to the ESP-wroom-32.
ESP says its receiving a null. I'm stumped. The reason for the 2 sec delay on the esp32, I was just trying to see if it recognized the pin being flipped from low to high on each side (it does).
Not sure where I'm going wrong with SPI comms.
Teensy code:
#include <Arduino.h>
#include <SPI.h>
const int slaveSelectPin = 40; // CS pin
const int readyPin = 9; // Ready pin
  SPI.begin(); // Initialize SPI
  pinMode(slaveSelectPin, OUTPUT);
  pinMode(readyPin, INPUT); // Set ready pin as input
  digitalWrite(slaveSelectPin, HIGH);
  Serial.println("Teensy 4.1: SPI communication test started");
  // Wait until the ready pin is HIGH
  if (digitalRead(readyPin) == HIGH) {
    Serial.println("ESP32 is ready to receive data.");
    char data = 'C'; // Data to send to ESP32
    Serial.println("Sending: " + String(data));
    SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
    digitalWrite(slaveSelectPin, LOW); // Select the slave
    SPI.transfer(data); // Send data
    digitalWrite(slaveSelectPin, HIGH); // Deselect the slave
    SPI.endTransaction();
    Serial.println("ESP32 is not ready.");
  delay(1000); // Wait for a second before checking again
ESP32 code:
#include <SPI.h>
const int slaveSelectPin = 5; // CS pin
const int readyPin = 33; // Ready pin
volatile bool dataReceived = false;
volatile char receivedData = 0;
void IRAM_ATTR onSPI() {
  dataReceived = true;
  pinMode(slaveSelectPin, INPUT_PULLUP);
  pinMode(readyPin, OUTPUT); // Set ready pin as output
  digitalWrite(readyPin, LOW); // Initially set ready pin to LOW
  SPI.begin(18, 23, 19, slaveSelectPin); // Initialize SPI with SCK, MISO, MOSI, and SS
  attachInterrupt(digitalPinToInterrupt(slaveSelectPin), onSPI, FALLING);
  Serial.println("ESP32: SPI communication test started");
  if (dataReceived) {
    receivedData = SPI.transfer(0x00); // Read data from master
    Serial.print("Received from Teensy: ");
    Serial.println(receivedData, DEC); // Print the received data as a number
    Serial.print("Character: ");
    Serial.println(receivedData); // Print the received data as a character
    digitalWrite(readyPin, LOW); // Set ready pin to LOW after receiving data
    delay(2000);
    digitalWrite(readyPin, HIGH); // Set ready pin to HIGH when ready to receive data
With SPI, one device has to be 'M' and the other/s 'S'.
I believe the Teensy and ESP are 'M' (by default).
